Tire Rack
Results 1 to 11 of 11
    Dec 2003
    775
    Default where is the low side ac port
    where is the low side port?
  2. #2
    goldsex's Avatar
    Jun 2005
    Lakeview, CA
    2,661
    Default Re: where is the low side ac port
    to the left of the hood latch assy, theres a hole in the front frame of the engine compartment.... (black Cap)
  3. #3
    Apr 2005
    107
    WRONG
    That's the high pressure port. Prepare for a world of hurt if you try to recharge through that side (if you can manage to get the fitting on).
    The low pressure port is accessible by taking off the passenger side headlight, or taking off the inner fender well. This has been asked a few times before, so search if you want more details.
  4. #4
    Dec 2003
    775
    I knew the easy one was the high.
  5. #5
    goldsex's Avatar
    Jun 2005
    Lakeview, CA
    2,661
    sorry guys !! I've never charged my a/c on my car but that's the only port I saw (or could find)
    Thanks for clearing up my mis-info !
  6. #6
    Oct 2000
    In ur srvrz patchin ur krnlz
    6,880
    If you have a long enough hose, you can latch onto the low side port without taking anything apart. I did about 2 years ago to check the low-side pressure.
  7. #7
    May 2005
    Liberty, In
    9
    did you find your low side port yet ? If you havnt, its on the top of the receiver/dryer, which is stuffed behind the front bumper cover, right hand side. Dont ask my why they put it there, i only work on them.
  8. #8
    Dec 2003
    775
    I was gonna do it for a friend, haven't done it yet. I felt around up there but didn't feel it. I couldn't see it from the top either.
    Is the duratec and the zetec in the same place?
    the dryer is the tube on the pass side next to the rad correct.
  9. #9
    Newbie
    May 2013
    1
    A couple of pictures from my girlfriend's 2002 ZX5. Hope this works:
    https://www.facebook.com/photo.php?f...type=3&theater
  10. #10
    Nov 2008
    1,024
    Yes, per second pic. You don't remove any parts but it helps to have long hose on your setup. Lay on your back to get to it, I do it all the time.
  11. #11
    Senior TEAM Member bflesher's Avatar
    Aug 2010
    Minnesota
    2,387
    Just reach up from the bottom of the car in front of the passenger tire. Much easier like amc49 said. Long hose helps and turn the wheels.
