FJ Gear Store
Results 1 to 13 of 13
    Nov 2005
    16
    Default PCV Valve question again - ZETEC
    I have a 2000 Focus ZX3 with the Zetec engine. I'm trying to figure out how to replace the pcv valve. I know where it is (under the head near the front next to the exhaust manifold area), but I can't for the life of me budge the thing! It seems as though the "hose" the is attached to the top of it is really a hard plastic pipe, and not a rubber hose that is flexible. I can't tell but it almost acts like this pipe is fastened to the block somewhere. Has anyone got an idea? I pull on the valve and it just does not want to move. By the way I have 130,000 on the car and would really like to get the puppy changed (I do not have any engine troubles though, no stumbling or hesitation, etc, just want to replace it cause it looks old)
    I've searched the forum before and while they show nicely where the valve is and how to remove it, it really does not seem to be the way as described for my car...
    Thanks!
    -niko
  2. #2
    [FJ] Addict
    Apr 2002
    19,264
    Default Re: PCV Valve question again - ZETEC
    yes its wedged into the front of the block... the best way to get it off is to pull the catalytic converter.
    The queen of the missions....
  3. #3
    Aug 2004
    Montreal
    251
    just pull on it !
  4. #4
    Super Moderators GapBoyPCS's Avatar
    Oct 2001
    11,243
    www.focushacks.com should have a method of removal.
    Richard
    2002 ZTS | Sangria Red |
  5. #5
    Jul 2002
    New Braunfels, TX
    10,540
    Dont you have to twist the valve.
    TXFO V.2.0
  6. #6
    May 2005
    770
    no, I just pull on mine and it will come out.
  7. #7
    Jun 2003
    Weston, Florida
    2,368
    Quote Originally Posted by c4uldr0n
    Same here.
    2011 MS3 LSM: SURE TorqR3 / SURE Countershift / SURE Aeros SRI / CorkSport boost tubes / CorkSport TIP / CP-E TMIC / OBX Racepipe + res delete / PAD Occ kit / Forge BPV V1 / Cobb AP Stage 1+ 93oct (tuned by me ~16psi) / Autotech FP Internals + DO Stage 2 Meth + 19psi Coming Soon!
  8. #8
    Oct 2000
    In ur srvrz patchin ur krnlz
    6,880
    The SPI had a twist-out. The zetec is just a pull-out job.
  9. #9
    Dec 2004
    Pittsburgh, PA
    98
    2000 zx3 should just be a pull out. I had to bend my wrist backwards until it dislocated and then pull it out. I think the dealers have a midget in their toolbox for these types of things. You know the old midget arm tool.
  10. #10
    May 2005
    770
    I may have to invest in this tool...
    Now, I can see hwo the pcv would be a pain with stock header/cat... but, still doable.
  11. #11
    Jun 2002
    Pa. (570 represent)
    2,375
    I replaced mine the other day, and even with my race header in place it was a tight fit for even my slender hands.
    Seriously, you just have to pull the hell out of it to get it out of there, it's really wedged into the oil separator and the tube connection is really tight as well. Just pull!
    Quote Originally Posted by 03ZX3drew
    I don't go to movies to think and read, I go to be entertained with as little thinking as possible. And the more explosions, blood, guts, and sex there is, the better for me.
    Dedicated to all things wrong-wheel drive - understeer.org
  12. #12
    Mar 2002
    Boston, MA
    59
    I have removed my ZX3's (Zetec) PCV from the top a few times and it is tight, even with small hands. When I was changing the oil, I saw how it is much much easier to do from under the car. You just reach up, pull the PCV out of the oil separator box and then remove it from the hose. Mine ends in rubber. Definitely try it this way, way easier.
    I pulled mine as I had a valve cover leak that tightening it a bit solved but checked the crakcase filter and the PCV. It looked clean and sucked up carb cleaner but I bought a new Purolator (PV250A) one, as mine has 65K on it. The spring seemed strong though. Anyway, the original PCV has all these small holes around the bottom and you can blow back through it almost weas easy as the other way. Normally a PCV is a one way check valve. The Purolator one looks more like most with just one hole in the bottom and flows one way. The car runs no different with the new one. There must be a reason for those holes though. I imagine the dealer has that type.
    Gary
  13. #13
    Senior TEAM Member G1-Focus's Avatar
    Dec 2000
    Greenwich, CT
    1,087
    If you have car ramps, then accessing the pcv valve from underneath is much easier than from up top and yes, it's a pull-off/out valve.
    Happy Motoring!!
    2001 Focus SE Sport
    2006 Impreza WRX 230/300
    Let LED's light your way!
