Central Florida Motorsports
Results 1 to 13 of 13
    Jun 2007
    Louisville, KY
    7
    Default Collapsed vacuum hose.
    Hi all. 2002 SE Zetec Dohc.
    Have a collapsed vacuum hose, need to know some specifics to tell the guy at the parts dept. The hose goes from the back of the intake, right below the throttle body, and runs to a pipe under the coil. Whats the official name for this hose? Also, I've never seen a clamp like the one on this hose. Doesn't appear to be the squeeze type or the regular type you loosen with a screwdriver. Almost looks like ya gotta pry it off. Any suggestions?
  2. #2
    Feb 2002
    Burnsville, MN
    846
    Default Re: Collapsed vacuum hose.
    PCV (positive crankcase ventilation) hose.
    Very common problem that they collapse when old.
    Also, you have to cut the crimped clamp (not reusable) of the hose to manifold and use a new hose clamp; screw or squeeze type-doesn't matter.
    2004 ZX3 2.3L Pitch Black, Manual - to be installed: Cosworth IM, CFM 67mm TB, AEM intake ,OBX header, Borla exhaust, CFM UPD, CFM BSD, Crane stage-1s, 4.06 FD, Torsen T2, Exedy OEM clutch
    2001 ZX3 Infra Red, Automatic - returned to stock
  3. #3
    Super Moderators GapBoyPCS's Avatar
    Oct 2001
    11,243
    Just an overall question: How are you folks replacing this hose? Are you attacking it from above or under the car?
    I'm thinking of replacing mine out of maintenance (hose hasn't been replaced since new)
    Richard
    2002 ZTS | Sangria Red |
  4. #4
    Feb 2002
    Burnsville, MN
    846
    I did mine from above, snaked my arm down there.
  5. #5
    Nov 2002
    oklahoma
    1,477
    Buy the factory parts, they're perfect. They just get old, hot and brittle over time. The front one is about 4 bucks, and the rear is around 6 bucks. Cheap enough to do it right. Common problem. I was able to get to both from the top fairly easily. Good time to replace the pcv too
    g
    Democracy is two wolves and a lamb voting on what to have for lunch.
    Liberty is a well-armed lamb contesting the vote.
    - Benjamin Franklin, 1759
  6. #6
    Jun 2007
    Louisville, KY
    7
    Hi all. Thanks for the info. Just replaced mine and went in from underneath. Plenty of room.
  7. #7
    Mar 2001
    New Haven, CT
    85
    Did you have an issue with rough idle? Did replacing the collapsed hose this fix it?
    your mom
  8. #8
    I Now Post Stupid **** Jibberish18's Avatar
    Apr 2003
    Chicago
    3,495
    Did you notice the last post was from 2007?
    "If You Never Had The Bad Times, How Would You Know You Had The Good Times?" -DEATH
  9. #9
    Mar 2001
    New Haven, CT
    85
    Still a good topic. Someone else may have found this post as I did and have an answer.
    I replaced my collapsed hose and the pcv valve and my idle is very solid when before it was lumpy at times.
    your mom
  10. #10
    TEAM Member Yachapohld's Avatar
    May 2008
    Fayetteville, TN
    327
    I just replaced my collapsed hose, and it helped smooth my idle.
    I keep reading that the clamp has to be replaced, but I was able to reuse mine.
  11. #11
    [FJ] Specialist Johnny_P's Avatar
    Nov 2004
    Philly, PA
    5,514
    ^ I think they suggest that because the stock clamp is a complete pain in the ass since its one of those hold-it-with-a-plier two tab clamp thingies.
    I had an extra screw-type hose clamp I used. Really just as long as you put something on there to hold it you're good.
    '12 Trek X-caliber // '11 Cervélo R3
    2010 VW GTI
    2000 Focus SE (sold)
  12. #12
    Apr 2003
    Chicago
    3,495
    I think the person who replaced mine didn't even use a clamp. Guess he figured the vacuum would hold the hose in. I think it's been okay for years now.
  13. #13
    May 2008
    Fayetteville, TN
    327
    Quote Originally Posted by Johnny_P View Post
    That's what I was thinking. But I didn't have an extra screw-type so I just kept trying.
