Central Florida Motorsports
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
    Feb 2002
    Louisville, Ky
    76
    Default Car wont start, makes a clicking noise
    Hey Guys and Gals, I am back again for your much needed help.
    My Focus died on me about 2 weeks ago, and now it wont start at all. It all started where every now and then, when I turned the key to start the ignition, it would just make this clicking noise, then after a few times, it would finally stop clicking, it would turn over and start. It only did that every now and then, till now, where thats all it will do. Whenever I turn the key, all it does it makes a clicking noise in the engine. Cant tell where the noise is coming from since I cannot get out of the car, look at the engine and turn the key at the same time.
    Any Ideas???
  2. #2
    [FJ] Specialist BowDown's Avatar
    Nov 2001
    NY State SUCKS!
    7,351
    Default Re: Car wont start, makes a clicking noise
    Try jumping the car with another car. Sounds like a dead battery... which could also be traced to a bad alternator.
    Project Red Sled: 2010 Sangria Red Metallic Fusion Sport - Custom SQ Stereo System, Phillips 6k HIDs
    Project WTF: 2007 Blue Suzuki Hayabusa - Shaved, Rear Links/Spacers (Lowered 1.25"), VisionPro 6k HIDs, Sport Bags
  3. #3
    Feb 2002
    Louisville, Ky
    76
    Not to sound like I totally know what I am talking about, but I dont think the battery is dead, all the lights and everything come on just fine and stay on when cranking the key, even 2 weeks after it last ran. So to me, the battery sounds ok, any other ideas. Thanks for the help, by the way
  4. #4
    Jul 2002
    New Braunfels, TX
    10,540
    your battery dosent have enough power to turn the motor over. It takes ALOT more current to spin the engine than it does to power the lights. so you have two options here. Its either because your battery is no good or because the motor is locked up.
    Try a jump start and report back.
    TXFO V.2.0
  5. #5
    Jun 2005
    Olympia Washington
    1,273
    That clicking is the starter solenoid trying to kick over juice to the starter to make it start turning the engine over.
    I agree with the above posts that suggest dead/weak battery. That's a good starting point and it's usually free. If you jump the battery and the car still won't start, at that point I'd be checking out my starter if I were you.
    Lookin' fast in the slow lane
    RIP, Jellybean (11/16/2001-6/16/2008)...you will be greatly missed.
    2003 Infra Red ZX3 SVT-Totally stock...FOR NOW!
  6. #6
    Feb 2002
    Louisville, Ky
    76
    Thanks all. Ok, Guess it wouldnt hurt to check the battery. Like you all said, its free, so, what do i have to lose. Could it be the starter solenoid, do you think?
  7. #7
    Jul 2002
    New Braunfels, TX
    10,540
    no. It's a ****ing dead battery.
    TXFO V.2.0
  8. #8
    Jan 2008
    NOVA
    65
    Hang on now....lets get the symptoms right. First, change the F***ING battery to an Optima or a truck battery in the same footprint, but taller. Get a bad-a** battery that is way over the OEM specs. Second, make sure that the terminals/connections aren't corroded AT ALL. I mean clean, sparkly clean, inside and out. Furthermore, if you have bought your fOCUS used, check all of the above, then make sure that the grounds are solid. Finally check to make sure the previous owner hasn't "cleaned" out the battery terminal clamps too many times. If you have to tighten the nut to the point of stripping, STOP. Replace everything from clean RED/BLACK to NEW battery. Sorry for the BOLDS and all the hype, but its a simple, commonly occuring problem that costs a lot of Foci a TON of money trying to figure out a simple problem.
    Beware the Dark Side of the Foci!
    Her name is Liliana, and she is happy. You have to keep her happy. They like new shoes. Especially Phillipino.
    16x7 Rota Slips, 215/50 Kumho ASX = Beefy
  9. #9
    Bacne..
    Apr 2001
    2,649
    LOL & who the **** is this guy^^
    coddle the weak
  10. #10
    Jul 2003
    Quakertown, PA
    971
    Joe's got Moxi, I can hand him that!
    And it probably is the battery, from what it sound like. My friend's spi was doing the exact same thing--heck, the op could actually be him posting!--until he drove on out and picked up a new battery.
    But, all of the other advice--checking grounds, cleaning terminals, etc.--certainly can't hurt, and should be on everyone's at least every once in a while "checklist" of underhood inspections.
    Cheerio!
    --Scott
    Move: PWSC w/ Esslinger gears, McNews tune, J&S Safeguard, FS wires, CFM tb, VF lower mnt, SVT header, TruBendz 2.5" flex/exhaust Carve: SVT shocks/struts/Vogtland springs, Eibach antirolls, Continental DWS tires Stop: Hawks Look: Yellow fogs w/ Nokyas & I.F. Mod, Euro upper/lower grille, blk headlight paint, sedan tail mod, Speedhuts, Mach lip from Tousley (installed by Brian Lokay).
  11. #11
    Jul 2002
    New Braunfels, TX
    10,540
    optima fan boy.
    I was going to delete the post but decided against it because most of it is actually good information. Everything but the optima/"truck battery" part. (trucks use the same ****ing batteries as cars. Besides, higher CCA sacrifices longevity and there is no sense getting a battery with a higher load rate or CCA than your car can actually use)
    TXFO V.2.0
  12. #12
    Mar 2007
    driftless WI
    5,333
    ^What about about a sailboat battery, they have loads of CCA and reserve, that should make the car go even faster than a truck battery will.
    Get a giant battery if you have a giant starter motor for a high compression big displacement engine, but if you have a stock 2.0 or 2.3 liter Focus, you just need one that is equal to stock recommendation. There's even a fudge factor built in.
    Silver SVTF w/EAP, #800 of 1,976 3drs, one of 87 built in 2004
  13. #13
    Senior TEAM Member v8FociDreams's Avatar
    Jan 2007
    Carlsbad, CA
    1,668
    Just take the ****ing battery to the parts house and have it tested. Its free and you will have a starting point.
    Quote Originally Posted by LamarWH
    Is Dateline NBC even trying anymore? Must have been the new one.... "To Catch A Jackass"
  14. #14
    Senior TEAM Member Terrible1's Avatar
    Oct 2004
    Idaho Falls, Idaho, United States
    4,220
    Thats exactly what my odyssey battery does when it's really cold. Doesn't have the CCA to turn the motor over, so it just clicks. Another vote for weak battery.
    Finally back to motorsports competition in my brand new 2013 Focus ST!!
    2013 Focus ST - Performance Blue - ST3 package
    #24 STX
    Cobb AccessPort - Cobb Intake - Cobb RMM - Eibach ProKit - Team Dynamics PR 1.3's 18x8.5 et48 - Dunlop Z2's 245-40-18
  15. #15
    Newbie
    Mar 2008
    1
    Exclamation Re: Car wont start, makes a clicking noise
    Hello all, I am having the same issues, I have tried replacing the battery with no luck. I have tried to jump the car, and it just clicks, Took the vehicle to get the alternator check and checked out fine.
    My question is could the wheel sensors have anything to do with the problem?The speedometer does not work as well, it works intermittently. my next step is to replace the starter. am at a lose here, any help would be awesome.
