Where is the oil drain plug on a 2008 Ford Focus? I would like to change the oil and cannot seem to find it.
(assuming they didn't change anything; I doubt they did) It is on the back of the oilpan. If you get underneath your car, you'll see the oil filter in the front, and on the opposite side of the oil pan will be the drain plug.
You didn't get any free maintenance with your car? I did.Originally Posted by starhubs
NEW: 2009 Ford Fusion SE - Blue Suede Package, 18" painted aluminium wheels, sport tuned suspension. GONE: -2003 SuperBlack 350z with a bunch of cool stuff
Originally Posted by LuvmyFoci
does the 08 have the same motor as the 05-07?
Chris
yup.
The Ford Focus, the 2.0 L engine at least, as I was told by a mechanic at a Ford Dealership... is not entirely the same from 2008 on. I was told that they changed the from a belt drive OHC to a chain driven system.
To order from me just call 1-800-328-9552 and ask for Steve or use one of the methods below.
2002 Silver SVT #2952 , Stage 2 throttle body, VF rear mount, FRPP 9mm wires, EAP/MACH HID's, Borla exhaust, Multimatic suspension, Screamin Demon coil, Tuned by Mike at Unique Tuning in S.C.
they all use a 13mm drain plug
01 zx3- AEM intake, B&M short throw, focus central UD pullies, focus central TB, borla catback, fidanza aluminum flywheel, vf engineering rear mount, s2 wing, eibach sportlines, 5% tint all around
