FSWerks
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    Apr 2010
    San Antonio, TX
    67
    Default focus zx3 oil dipstick
    anyone have the part number for this? I know how to order it and all but I need to know if I have the correct oil dipstick in my zx3. Also, is it the same dipstick as the zx2?
    I keep having oil leaks in the zx3 and im starting to think that its cause I have the wrong oil dipstick in the zx3. I measured the oil with the zx2 dipstick and the oil level seems just where its suppose to be, but with the one the zx3 has, it always reads low (hence I refill and it all ends up leaking). The dipstick I have on the zx3 is shorter than the zx2 dipstick.
    "zx3" dipstick part #: ys4e 6750 za
    zx2 dipstick part #: f8ke 6750 aa
    1998 Ford Escort Zx2 (modded)
    2001 Ford Focus Zx3
  2. #2
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,858
    Default Re: focus zx3 oil dipstick
    How much oil are you putting in after an oil change and what does the ZX3 dipstick read then?
    Joe
    2013 Oxford White ST
    1985 Nimbus Grey Merkur XR4Ti
  3. #3
    Apr 2010
    San Antonio, TX
    67
    When I made the oil change, I put 5qts. the dipstick read above the full level.
    2001 Ford Focus Zx3
  4. #4
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,858
    That's probably why you are leaking. The Focus Zetec takes 4.5quarts with a new filter.
    Joe
  5. #5
    Apr 2010
    San Antonio, TX
    67
    true but thats why I need to make sure I have the correct dipstick also..
    2001 Ford Focus Zx3
  6. #6
    May 2010
    25
    why not try putting in 4.5 quarts and see what the dipstick says, if its anything other then full then you have the wrong one
  7. #7
    Apr 2010
    San Antonio, TX
    67
    lol, im broke right now and dont have money to buy another 5qts of oil. also, I dont have anything to measure quarts either. can someone check their zx3 dipstick and get the number at the tip just to comfirm or rule out this possibility. mine reads: ys4e 6750 za
    ps thanks everyone who has replied to this!
    2001 Ford Focus Zx3
  8. #8
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,858
    I have the SVT one so I can't help there, sorry.
    You don't have to measure the quarts with anything else, it shows a level with measurements on the side of the container. I think the reason you're leaking is you are overfilling which can cause leaks, blow out seals and damage to the motor. I think what Jon mean was next oil change, put in 4.5quarts, put it on level ground and then see what the dipstick says. That is your "full" mark.
    Joe
  9. #9
    Aug 2008
    College Station, Texas
    144
    its the same. im pretty sure we've been over this lol.
  10. #10
    May 2010
    25
    yea that is what i meant. i work in a tire and lube shop and we see this very often, customers assume that since it comes in a 5 liter jug that the car needs all 5 liters, so then the oil starts to come up the dipstick tube, or if that's tight it can start to do damage like blow out the oil pan gasket
    just my 2 cents
  11. #11
    Apr 2010
    San Antonio, TX
    67
    Thanks again everyone for their replies!
    very much appreciated
    2001 Ford Focus Zx3
  12. #12
    Apr 2010
    San Antonio, TX
    67
    ok so I mnaged to find a 5qt jug with the measuring strip at the side. I drained the oil and put back only 4.5 qts this time. I measured the oil with the zx2 dipstick and it was way over the fulll level. about 3 times. Then I measured it again but with the zx3 (shorter) dipstick and the oil was about and inch over the full level. im confused now =\
    2001 Ford Focus Zx3
  13. #13
    Aug 2008
    144
    both dipsticks should be the exact same. can you take a picture please? if you filled up the car with exactly 4.5 qrts, there is no way its overfull unless you didnt drain the previous oil entirely.
  14. #14
    Apr 2010
    San Antonio, TX
    67
    ok, I did drain the previous oil. did exactly 4.5 qts. and heres the pic
    The small one I use on the focus and the longer one is from the zx2
    ^^^^^^^^^^^^ that is not my foot!
    2001 Ford Focus Zx3
  15. #15
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,858
    I'm guessing you didn't replace the filter?
    The Zetec is 4.5qrts with a new, empty oil filter. If the old filter was on there it was full of oil and now you're still a bit overfull.
    Joe
