Massive banner 1 - 2014
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Jan 2011
    5
    Default Ford Focus dies at cold start if not step on gas pedal
    2002 Focus with 2.0L DOHC Zetec engine. At cold start, the engine would start, but the speed would drop and die if not stepping on the gas pedal. If I step on the pedal once and get the engine speed QUITE high, and then let go the pedal, it will run fine then, and I can drive without any other problem. I don't really need to keep it at high speed for any time, and so I don't think it's warming up issue. It always starts and runs fine when warm. I just replaced the idle air control valve yesterday, but that didn't get rid of the problem.
    The old IAC valve looks suspicious to me. The whole valve stem is covered with a layer of dust. I would expect a section without dust the the valve stem moves up and down when it works. But then the new IAC valve didn't fix the problem.
    Hope someone can help. Thanks.
  2. #2
    goldsex's Avatar
    Jun 2005
    Lakeview, CA
    2,661
    Default Re: Ford Focus dies at cold start if not step on gas pedal
    This....
    Resident AEM, K&N and Spectre Performance guy.
  3. #3
    Jan 2011
    5
    Thanks for your suggestion. So I went out and took a look. Mine looks fine as far as I can see and feel. It then goes under the manifold, and I can't see the other end. Is it PCV tube?
  4. #4
    goldsex's Avatar
    Jun 2005
    Lakeview, CA
    2,661
    Yes, Check it while it's running that's when it looks like it's collapsed.
  5. #5
    Jan 2011
    5
    Checked. Still looking fine while running. Thanks.
  6. #6
    baker of shartmuffinz hyprshart's Avatar
    May 2010
    2,569
    my money is on the IACV (idle air control valve) it is located on the intake mani near the middle. you cant really test it, i ad an idle problem that it would stall whenever the A/C was on, changed it and it fixed it.
    not a cheap fix (at least to me) cost me $75 at autozone
  7. #7
    goldsex's Avatar
    Jun 2005
    Lakeview, CA
    2,661
    He already replaced it.... The only thing I can think of is a Vac leak that seals up when the car gets warmed up as the seals expand from heat.... I would bust out the propane torch and start looking for leaks.
  8. #8
    Mar 2007
    driftless WI
    5,280
    Does this happen all the time when it's cold, or only under certain conditions, like a frosty/foggy/humid morning about 32-36 degrees?
    Mine starts on no more than 3 cranks, and immediately settles down to a smooth idle, almost always... except when conditions are as stated above. Then it cranks several times, misses, stumbles, and needs to be blipped once or twice before it will smooth out. I'm thinking in my case, it might be an issue with the MAFs or just the IATs part of it... something to check, anyway.
    Silver SVTF w/EAP, #800 of 1,976 3drs, one of 87 built in 2004
  9. #9
    goldsex's Avatar
    Jun 2005
    Lakeview, CA
    2,661
    Never thought of the MAF sensor, then again I don't see how the MAF would clear up after raising the idle XXXX RPM and then the car runs fine afterwards. It's worth a shot to clean out though,
    Try this stuff....
  10. #10
    May 2010
    2,569
    Quote Originally Posted by goldsex View Post
    DOH i was half asleep.... yah thats my alibi
  11. #11
    goldsex's Avatar
    Jun 2005
    Lakeview, CA
    2,661
    Quote Originally Posted by hyprshart View Post
    I think your smellin what your avatar is cookin'
  12. #12
    May 2010
    2,569
    is that what that warm stuff is?? ohh man.......
  13. #13
    I Now Post Stupid **** Jibberish18's Avatar
    Apr 2003
    Chicago
    3,495
    Is the engine flooded with fuel from running rich by any chance?
    "If You Never Had The Bad Times, How Would You Know You Had The Good Times?" -DEATH
  14. #14
    Jan 2011
    5
    Flooded with fuel? it reminded me that it feels that if I shift to park and shut the engine down right away, I tend to have more problem. If I let it idle for a few seconds and speed come down, it tends not to have problem. But I didn't pay much attention to this. I'll give it a try this weekend and see if there is really such a difference.
    While looking around the car yesterday, I noticed that the piece of sponge in the air filter box, which covers the fresh air inlet of PCV system, is soaked with some oil and crumbed. So I throw it away, and replaced with another piece of sponge. So far I haven't had problem during the 2 starts today, one going to work and one leaving work. I'll post what I find out this weekend. Thanks.
  15. #15
    goldsex's Avatar
    Jun 2005
    Lakeview, CA
    2,661
    That's the carbon trap, Make sure you replace it with the right parts, a kitchen sponge won't hold up.
    A leaking fuel injector might cause a hard start issue by flooding the cylinder, when you shut the car off and the injector is stuck open it will bleed the fuel presure off into the cylinder. This would more than likely cause a CEL though. And if this is happening you can look forward to an engine rebuild from the fuel washing out the cylinders, Hopefuly this isn't the case.
