Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Motorsport > NASA Spec Focus Series
www.nasaproracing.com
Old 10-31-2007, 07:40 AM   #1 (permalink)
Default Water and Water Wetter? Freeze Warning
To all you guys running water and water wetter - frost warning. Reminder to change it out for antifreeze for the winter to avoid cracked blocks. That will save a frantic effort under the car in the dark draining the water when the big cold snap comes through (like I had to do on Monday night)
Or - clean out your garage so you can keep it inside and warm.
2007 NASA Mid-Atlantic Spec Focus Champion (Undefeated in a class of 1)
2007 Spec Focus National Championship - 4th place
2006 NASA Mid-Atlantic 944 Supercup - Champion
Matt Marks is offline
Old 10-31-2007, 12:16 PM   #2 (permalink)
Ted7rns's Avatar
Default Re: Water and Water Wetter? Freeze Warning
antifreeze?? Do we need that in SoCal?
2002 Ford Focus ZX3 Malibu Blue
Ted7rns is offline
Old 10-31-2007, 12:43 PM   #3 (permalink)
I juuuuuuust did that in time-It was 50 or so on sunday and I siphoned some of the water/WW mix and put in straight coolant...that night it got down to 25 or 30. lucky lucky!
--UnFocused1-- AKA >>Matt<<
--01 Focus "FCS-PWR" 350+whp Work-In-Progress--
<03 Ranger 4.0L "SKIGOD" DD: CAI, custom side exhaust, audio>
>86 Ninja 250R "GOPED" 50+mpg bullet: Slip-ons, Pod filters, Jet kit, LED signals, custom plate bracket<
polarisman14 is offline
Old 10-31-2007, 03:09 PM   #4 (permalink)
That was my first thought.
"I see in the near future a crisis approaching that unnerves me and causes me to tremble for the safety of my country. . . . corporations have been enthroned and an era of corruption in high places will follow, and the money power of the country will endeavor to prolong its reign by working upon the prejudices of the people until all wealth is aggregated in a few hands and the Republic is destroyed." -- U.S. President Abraham Lincoln, Nov. 21, 1864
Cameroon is offline
Old 11-01-2007, 07:55 PM   #5 (permalink)
Do you have something to stop the corrosion? As much an issue as freezing
LEM
2007,2008, 2009 NASA Spec Focus racer w/ LCR racing
2002 SVT, Sonic Blue, NO options,
vehicle 896 of 4788
Held at the factory Apr-June 02
SVTBuckeye is offline
Old 11-01-2007, 08:49 PM   #6 (permalink)
Ted7rns's Avatar
I would always use Royal Purples' Purple Ice which works for rust, corrosion and erosion.
Ted7rns is offline
Old 11-02-2007, 10:35 AM   #7 (permalink)
No experience with the Purple Ice, but what I do know is that Water Wetter increases cooling by reducing the surface tension of the water against the head and coolant passages, which keeps it in better contact with the metal. The result is better cooling (more water/coolant touching the metal) and a decrease in microscopic hot spots causing "mini" boiling points --->> erosion
Also has additives to lube the water pump and prevent the seals from drying out and leaking.
THere are some really good technical articles on the product at redline's website along with real technical data of cooling effects on a test motor with varying amounts of coolant/water/water wetter. I think it's www.redlineoils.com
Cool reading if you're a techno geek ;-)
I assume that the Purple Ice functions in a similar fashion with similar results. No one seems to stock this stuff in my area - so I use W.W. as a default.
Oh - and always use distilled water! Tap water --->> full of minerals --->> bonds to aluminum --->> big erosion
Old 11-02-2007, 10:58 AM   #8 (permalink)
[FJ] Addict
Water wetter does have corrosion fighting properties. It's good stuff, but don't expect a 24 degree improvement, or whatever they claim on their website. I probably got a consistent 5 degree improvement in my truck. I guess it might do a bit better if I drop the coolant level...I still run a 50/50 mix and top off with a bottle of WW.
Mountain Tested----'03 zetec
ZX3 vs MNTN - 15-1 & ZX3 vs TRACK - 23/1 JCM Racing #88
Back to Dual Purpose Focusing
Vacuum Vulture Racing - We add stiffness
brads03zx3 is offline
Old 11-02-2007, 12:01 PM   #9 (permalink)
Ted7rns's Avatar
Purple Ice does the same thing as wetter water. http://www.royalpurple.com.au/files/...T/prpiceps.pdf
Ted7rns is offline
Old 11-02-2007, 02:23 PM   #10 (permalink)
And they're both colorful and non-toxic. Put a cocktail umbrella in them, pour over ice, and you have delicious trackside beverages.
Old 11-02-2007, 02:34 PM   #11 (permalink)
Ted7rns's Avatar
Ted7rns is offline
Old 11-02-2007, 02:37 PM   #12 (permalink)
I rather have a JACK!!!
Leo
NASA Spec Focus Series Director
www.capaldiracing.com
"Quitters Never Win"
68 Touring Car is offline
Old 11-02-2007, 03:23 PM   #13 (permalink)
Ted7rns's Avatar
Leo, That's not a surprise to any of us.
Ted7rns is offline
Old 11-03-2007, 12:42 AM   #14 (permalink)
[FJ] Addict
Brad, I disagree. From coolant to water is a HUGE difference. from water only to water+water wetter was a slight difference. I did some datalogging, but they're on my old laptop... but the difference was major.
In the Focus, using 50/50 coolant water, the temp hovered right around 180* on a 50* day. Drain the coolant, go to straight water (as best I could) and the temp would barely break 140*. Running when it was in the high 30s low 40s the temps were no higher than 120* and the needle on the dummy gauge would barely come off the cold.
Focus Challenge Director | Redline Time Attack Host and Emcee | Spec Focus Racer
BUR_ZX3 is offline
Old 11-03-2007, 01:46 AM   #15 (permalink)
Associate Sponsor
What about Patron!
Authorized Dealer for: Brembo Brakes, Clutchnet, Vogtland, Eibach, Koni, Tokico, Ingalls, Ireland Engineering, Crower Cams, Supertech, ACT Clutch, ARP Studs, Kyowa Wheels, Nitto Tires, Toyo Tires, StopTech Brakes, Centric Brakes, TurboSmart, Cosworth, Street Scene. www.f2focus.com
Vehicles: 2008 Ford Fusion, 2008 Focus Coupe, 2010 Mazda 3 (Coming), 2011 Fiesta (planned)
f2focus is offline
Old 11-04-2007, 11:50 AM   #16 (permalink)
[FJ] Addict
Todd, did you read all that I wrote? I didn't make the jump from 50/50 to water+WW. I still run a mix with WW. I said I would probably see a better improvement if I took some or all of the coolant out, but it is not worth it to me on a street vehicle that does see freezing weather.
Old 11-04-2007, 11:36 PM   #17 (permalink)
[FJ] Addict
Sorry... my ADD musta kicked in by that point.
BUR_ZX3 is offline
