http://www.nasaproracing.com/rules/ccr.pdf
Spec Focus Changes.
The Spec Focus Advisory Board and NASA has approved the 2008 rules. We’re very pleased with the changes that were made. There was not one single rule that was posted online or emailed to use, that we did not go through. Not all of them was approved by the board and some where not approved by NASA. Ford Racing help us with all the engine facts and other performance related questions.
Here’s a general list of some of rule changes for 2008. (Other rules the wording was change)
Models Added: 2008 Sedans and Coupes can be used in SF racing.
Minimum Weight: increase (2.0L +25lbs and 2.3L +50lbs)
· 2.0L Zetec 2,600 lbs
· 2.0L SVT 2,600 lbs
· 2.0L Duratec 2,600 lbs
· 2.3L Duratec 2,675 lbs
Compression: has changed from +.50 increases to the following.
· 2.0 Zetec: 10.5 to 1 Max
· 2.0 SVT: 10.5 to 1 Max
· 2.0 Duratec: 10.5 to 1 Max
· 2.3 Duratec 10.0 to 1 Max
Throttle Body: 2.3L must use OEM TB Only. The others are the same as last year
HP-to-WP ratio has be omitted from the rules, Engine Claimer rule is still in place.
RPM Limits:
· Duratec 2.3 6800 rpm
· Duratec 2.0 7200 rpm
· Zetec 2.0 7200 rpm
· SVT Zetec 7000 rpm
Final Drive: has changed for 2.3L cars only, They can only use 3.42:1 and 3.82:1 only (No 4.02 for 2.3s anymore)
Part Numbers for 3.82 Gears
YS4Z-7F343-FA 3.82 Ring Gear
1S7Z-7061-AA 3.82 Output Shaft
Suspension: Spec Focus Damper and Spring kit from FRPP has been added.
Ford Racing Spec Focus Damper Kit (2000-05) M-18000-ZXM
Ford Racing Spec Focus Damper Kit (2006-08) M-18000-ZXM1
Ford Racing Spec Focus Spring Kit (2000-05) M-5560-ZXM
Ford Racing Spec Focus Spring Kit (2006-08) M-5560-ZXM1
Tires: R888 215/45x17 wheels have been added until June 1st then only R888s can be used.
· Any 17x7 inch OEM Ford wheel may be used. This includes SVT and Ford Racing wheels.
· Effective January 1, 2008, allowed tires shall be Toyo R888 in size 215/45/17 and Toyo RA-1 in size 205/40/17.
· Effective June 1, 2008 the only allowed tire shall be the Toyo R888 in size 215/45/17.
Brakes: SVT Kits have been added for newer cars by FRPP. The brake system can be upgraded to any of the following components
· SVT Brake Kit M-2300-ZX3
· Ford Racing Rally Brake System M-2300-ZX3R
· SVT Front Brake Kit M-2300-SVTF4 (MY 00-05)
· SVT Front Brake Kit M-2300-SVTF5 (MY 05-08)
· SVT Rear Brake Kit M-2300-SVTR (MY 00-08)
· Ford Rally 15" Front Brake Kit M-2300-ZXR
Decals: All SF cars now must have Spec Focus Number Plates and Ford/Spec Focus Windsheild banners. (price TBA). They are like the ones that were used at Nationals.
· Spec Focus number plates on each side of the race car
· Official Ford/Spec Focus windshield banner
