Focus Performance
www.nasaproracing.com
Old 12-13-2007, 12:48 PM   #51
brads03zx3
Default Re: 2008 Spec Focus Rules
Originally Posted by Ted7rns
^^^^And if Chris had his motor blueprinted..
because blueprinting was in the original motivation for the series
sounds like we will have spec miata engines here before too long.
Mountain Tested----'03 zetec
DuraMonster---'03 duratec
Old 12-13-2007, 02:02 PM   #52
Ted7rns
^^^ Nope because we will add back our Hp-to-Weight Ratio. The only reason we dropped it was we didn’t think it was necessary at this time.
Ted7rns is offline   Reply With Quote
Old 12-13-2007, 08:23 PM   #53
68 Touring Car
As far as I know none of the car that ran the Nationals had blueprinted engines? Ted do you know some thing the rest of us should know? Chris's SVT made very good power and he still can put a tune on it.
Leo
www.capaldiracing.com
"Quitters Never Win"
68 Touring Car is offline   Reply With Quote
Old 12-13-2007, 08:28 PM   #54
Ted7rns
As far as what? I got those numbers from you or Ford If it’s something else… well psssssss it’s a secret.
Old 12-15-2007, 05:46 PM   #55
Matt Marks
Please also remember that the series is still very young, so changes to formula used for power - whether RPM limits, HP/TQ/WT, etc - are bound to change. Part of the factor is that it's not easy to tell who can get what power out of which motor within the scope of the rules. If racer's start to build (for example - SVT guys stay chilled) blueprinted SVT motors that consistently make 170, then they will have moved the benchmark for what that motor is evaluated on - and therefore other factors will be adjusted to compensate. i.e the assumption would then be that all SVT motors are capable of 170.
For example - the 2.3's proved to be the fastest in 2007, so they were reined in for 2008 by increased weight and limiting R/P to 3.82.
Also, - if someone is making far too much power, NASA has the right to claim the motor if they so choose.
2007 NASA Mid-Atlantic Spec Focus Champion (Undefeated in a class of 1)
2007 Spec Focus National Championship - 4th place
2006 NASA Mid-Atlantic 944 Supercup - Champion
Matt Marks is offline   Reply With Quote
Old 12-15-2007, 11:01 PM   #56
jezwald101
but you also increased weight of the zetec engine which never won a race....jesse
jezwald101 is offline   Reply With Quote
Old 12-16-2007, 05:11 PM   #57
Ted7rns
We increased the weight to all 2.0 cars, mainly because it made it harder for the Sedans to get down to 2575lbs. But the 2.3L is still 75lbs heavier then all the 2.0L
Old 12-16-2007, 09:01 PM   #58
jezwald101
dont understand,it made it harder for the sedans to get down to 2575lbs????
Old 12-16-2007, 09:15 PM   #59
brads03zx3
2575 was the previous minimum weight. It was too difficult for the sedans to get to that weight, so they raised the minimum weight for all cars up to 2600. Because they felt the 2.3 had an advantage, they raised the weight of those cars even higher.
Old 12-16-2007, 09:20 PM   #60
jezwald101
too difficult to get to the weight???????
Old 12-17-2007, 08:11 AM   #61
Matt Marks
Believe me - it is not easy to get the sedans to that weight
Old 01-10-2008, 10:25 PM   #62
InFocusTraSTi
Hey guys I was looking over the rules but didn't see anything on Battery relocation? Is it legal?
InFocusTraSTi is offline   Reply With Quote
Old 01-11-2008, 12:31 AM   #63
Ted7rns
Yes, you can relocated it.
Old 01-11-2008, 10:03 AM   #64
InFocusTraSTi
Is there anywhere that I can follow a guide line to what meet tech inspection? I know in some places you need to vent the battery box to the outside of the car. I just want to get that right if I decide on doing so. Also what about mounting it. I would probably go with a battery box that would be strapped down to the car but I haven't look to deep into this.
Old 01-11-2008, 11:22 AM   #65
CCapaldi
We've used the Moroso sealed box in the past.
http://www.rpmoutlet.com/musv6batt.htm
2007 & 2008 Spec Focus National Champion
CCapaldi is offline   Reply With Quote
Old 01-11-2008, 12:33 PM   #66
Ted7rns
In NASA CCRs it states the following.
18.8 Battery
The battery shall be securely fastened down to the car. No Bungee cords or rubber cords may be used to function as the sole hold down mechanism. An electrically nonconductive material must cover the positive battery terminal. Any battery located inside the driver’s compartment shall be fully covered and firmly secured to the chassis in a marine type battery case. True dry cell batteries may be mounted without a surrounding case, however a case is still recommended. Note- there is a difference between “dry cells” and “gel cells.” Gel cells still need to be mounted in a case.
Old 01-11-2008, 04:20 PM   #67
InFocusTraSTi
OPtima Red top is that dry (I believe it is...)
Old 01-11-2008, 05:29 PM   #68
Ted7rns
No Optima are SpiralCell Technology. But, they are still acid filled cells. The Dry cells are like the Odyssesy Race Batteries.
http://www.flatironstuning.com/shop/...batteries.aspx
http://www.optimabattery.co.uk/engli.../technical.htm
Old 02-06-2008, 10:02 PM   #69
InFocusTraSTi
Hey guys sorry for asking so much but is there any rule that would not permit a balance shaft delete on 2.3L duratec? I really wouldn't know under what that would fall because I don't think it is part of flywheel but then again there probably is a rule not permitting me to do so.
Old 02-07-2008, 12:31 PM   #70
InFocusTraSTi
To answer my own question I gues this rule would eliminate the balance shaft delete.
11.2 Balanced and Blueprinted Engines
Engines may be balanced and/or blueprinted. Lightning of parts beyond what is necessary to balance is
prohibited. Only the minimum of material should be removed from any engine component during a rebuild
process.
Old 02-28-2008, 07:12 AM   #71
68 Touring Car
Default Re: 2008 Spec Focus Rules and Technical Bulletins
I moved a copy of the technical Bulletins here so we could loose one more stickey.
Re: Technical Bulletin 2008
Technical Bulletin for RPMs for SVT Motors.
The RPM limits for the SVT Motors have been changed from 7,000 to 7,400 rpms.
NEW RULE for 11.20 RPM Limits
The following RPM limits shall apply:
• Duratec 2.3 6800 rpm
• Duratec 2.0 7200 rpm
• Zetec 2.0 7200 rpm
• SVT Zetec 7400 rpm
Any means of the driver adjusting either RPM limits and/or engine management software during a
Ted7rns
Clarifications to rule 6.1.2 Engine/Transmission.
I have received an email and also replayed to a post in the NASA forums about Mazda Engines.
Currently under the 2008 Spec Focus Rules only Ford Duratec, Zetec, and SVT motors can be used. Mazda MZR 23 and MZR 20s are not allowed. Also Euro Duratec Motors and ECUs is not allowed as well.
Ted7rns
In the rules where it states OEM, that means US Market OEM items. Not Euro OEM.
Matt Marks
Theres a note in the rules (Section 6.1) which states that "all parts, unless otherwise noted, must be from US or Canadian models in mass production, and must be commonly available." So I think you have this covered.
Leo
