www.nasaproracing.com
Old 06-16-2008, 10:47 AM   #1
Egz
Default Battery / alt kill switch wiring for a Duratec?
Not that I'm building a SF car, but I'm sure some of you guys have wired in a battery kill switch in a Duratec Focus, so I was wondering how you did it. With the COP setup, it looks a little trickier than the usual cut-power-to-the-coil type setup.
Plus, what brand kill switches are you guys using?
Thanks!
Duratec Wiki - Sign up and contribute!
For Sale: Dome Map Lights - XM Roady - Differential - Crash foam - Blue Air Vents
2003 Ford Focus ZX3 2.3l N/A = 201HP, 157ft-lbs; 13.96@100.88
2006 Ford Fusion SE 2.3l Turbo = 244HP, 247ft-lbs, FSWerks Built
Egz is offline   Reply With Quote
Old 07-18-2008, 01:38 PM   #2
Matt Marks
Default Re: Battery / alt kill switch wiring for a Duratec?
On my duratec, I cut the wire going to the main ignition fuse, and spliced into a generic 6 pole switch (what i had in the garage), but for my application a 4 pole would have worked.
I didn't figure out how to dump the alternator, etc - but figure that the switch gets used maybe once or twice a year at annual tech - so the alternator would be fine.
I'm sure there's a better solution out there, but this one worked. I *think* that Leo does the same on his cars, but instead he tapped into the wires coming off the ignition switch.
He has the kill switch on the roll cage, whereas mine is in the engine bay with a pull cord to activate it. YMMV
2007 NASA Mid-Atlantic Spec Focus Champion (Undefeated in a class of 1)
2007 Spec Focus National Championship - 4th place
2006 NASA Mid-Atlantic 944 Supercup - Champion
Matt Marks is offline   Reply With Quote
