NASA Spec Focus
www.nasaproracing.com
Old 08-21-2008, 08:28 AM   #1
gburner
Default svt oiling problem/issue??
I'm getting ready to do my first lapping day w/ my 03 svt. I was looking at a thread w/ a broken rod(ouch !). I'll be on r-dot rubber w/the stock alignment.Do I need to worry/slow down or just make sure my oil is full?.....thanks, mike.
2003 black EAP svt
gburner is offline   Reply With Quote
Old 08-21-2008, 08:41 AM   #2
BadIdea
Default Re: svt oiling problem/issue??
Nope - zero oil issues on the svt. Power steering and front hubs are a different story.
'02 silver svt
'08 tundra crewmax
BadIdea is offline   Reply With Quote
Old 08-21-2008, 08:52 AM   #3
gburner
power steering issue I understand( neon acr owner) How long do the front hubs/bearings last under race conditions ?? thanx ...mike
2003 black EAP svt
Old 08-21-2008, 12:47 PM   #4
Ted7rns
Alot of that depends on the Suspension, Tire size, type of tires, and wheel weight.
If you have a very stiff suspension with high grip Hoosier Race tires that are on 225 tire width... the front hub will not last as long as a track car with shofter suspension with 205 width, High Performance Street tires.
Our Spec Cars seem to have less issues with hubs then other track Foci.
Ted7rns is online now   Reply With Quote
Old 08-21-2008, 02:17 PM   #5
mzemnickas
A couple notes on the oiling issue. I ran into this problem last weekend at Mid-Ohio. It appears that the SVT engine is very sensitive to changes in internal pressure so having a good overflow tank (with a breather) is very good idea, also make sure that the dipstick is secured in the tube and the 0-ring is present on the stick (use a zip tie to secure it in the tube if necessary). If you watch these you shouldn't have any issues.
Have fun!!!
mzemnickas is offline   Reply With Quote
Old 08-21-2008, 07:59 PM   #6
ckisner
make sure your oil level is correct and let 'er rip! almost 2 full seasons and no issues.
Spec Focus Advisory Board Member
'02 Sonic Blue Focus SVT (Spec Foci)
ckisner is offline   Reply With Quote
Old 08-21-2008, 09:26 PM   #7
SVTBuckeye
First use a synthetic engine oil
consider same for power steering,
You may leave the level of the engine oil a little low, half way between full and add, this avoids any whiping of oiil by the crank/rods. Not a requirement however,
Wheel bearings go because folks overheat the hubs, grease melts, byby bearing.
Thus, cooling duct work to brakes is highly desirable. Remove fog lights, duct to about 10 inches from rotor. closer will find the wheel hiting the ducting. See other threads for various duct ideas etc.
You will be most happy if you get a dedicated set of rotors and high performance pads beded to those rotors. Not required, but makes for great brakes, and your street set up is preserved. Don't put Carbotec pads on a used rotor, the material will NOT transfer evenly and you will have high speed chatter from H#$%.
Have fun
PS a missed shift, like 3 to 2 rather than 4 will make all bets off. DON"T do it. Bad Stuff happens
LEM
2007 & 2008 NASA Spec Focus racer w/ LCR racing
2002 SVT, Sonic Blue, NO options,
vehicle 896 of 4788
Held at the factory Apr-June 02
SVTBuckeye is offline   Reply With Quote
Old 08-22-2008, 08:06 AM   #8
gburner
Thanks....everyone !!! I do have some experience w/roadracing ( scca ITB omni ) I just wanted to know about the possible problems w/ the svt....mike
2003 black EAP svt
Old 08-22-2008, 08:39 AM   #9
Laze1
So you guys normally run an "Accusump"?
Time Trials today, W2W when my kids get real jobs
Laze1 is offline   Reply With Quote
Old 08-22-2008, 11:32 AM   #10
BadIdea
No. For the svt's (and i assume all the others) you need full synthetic like a mobil 1 and breather. I actually have a steeda elbow so I send it right back to the intake but it is AFTER the mass air sensor. Stock and alot of other intakes send it back before the mass air sensor.
'02 silver svt
'08 tundra crewmax
Old 08-22-2008, 01:00 PM   #11
Laze1
The Accusump is a secondary/ external oil accumalator...if the oil pan runs dry thus droping ebgine oil pressure, the "Accusump" (brand name of a common device) tank of 1-3 Qts of oIl are forced back into the oiling systems,,,,thus preventing a "dry engine"
Old 08-22-2008, 01:05 PM   #12
BadIdea
Again, no one has an accusump and I don't see a need for it. But thanks for explaining what one is.
'02 silver svt
'08 tundra crewmax
Old 08-22-2008, 02:25 PM   #13
BUR_ZX3
[FJ] Addict
Yeah. We all didn't know.
its ok Noob.
Video from the final round of the Focus Challenge... Click Here
BUR_ZX3 is offline   Reply With Quote
Old 08-22-2008, 08:30 PM   #14
gburner
I used one in the omni...even if you never have any oiling issues you can use it to pre oil the engine before you start it( priceless )
2003 black EAP svt
