I wonder if this will work ??? anyone know ??
Up to 50% higher spark-gap current than comparable digital CD’s!
Exclusive new Plug-N-Go INSTALLATION! No “cut-crimp-solder”, just fast Plug-N-Go!
New, bigger external rotary switches for easy rev limit adjustments. No “CHIPS” Needed To Adjust Rev Limits!
New Intelligent RPM Control, plus the latest generation of sequential rev limiting.
Fully potted with new, soft urethane for heat, dirt and moisture protection.
Surface-mount technology (SMT) robotic assembly... like cell phones! The most reliable CD ignition available!
Exclusive Cross-Fire protection, for super-charged or turbo applications.
Built-In timing retard capable with optional Part Number 6000-6446 Control Module.
Built-In Tach-Check™ feature, and built-in Diagnostic System with fault-codes.
Eliminates “check engine” light, no-crank, tach and INOP fuel pump problems. CARB approved for OBD I & II vehicles Polished and Color-Matched Trigger is included in Ignition Kit
Go for the eyes BOO
Go for the eyes!
Linear Mode
