Re: idle
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by quaverous:
Richard - it can be problem because the fuel pump uses the gas as a coolant. so if you run really low, the pump is not being cooled properly. hence that is why most people discover their fuel pump recall when they have very little gas.
<hr></blockquote>
Quaverous, i'm not sure if you read the post created by Stealth Zixxer about taking a turn hard and feeling as if your fuel cut off in the turn...i myself have experienced this too...would my not keeping gas levels high enough contribute to this fuel pump problem?
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr> focused - I would say if you have 20k + miles, the cleaner will help. your engine timing is properly not off, since you haven't tinkered with it. do the cleaner with 93 octane gas, if it doesn't clear up, we're gonna need some more info. Does it run rough all the time, when cold, when warm?
<hr></blockquote>
eh, only 15k miles but unfortunately, the low gas level has happened many times...would that change your answer in any way?
i'll try it next time i get my tank filled up with 93...what about 94? i'm not sure if i have 93 around my way but if i see that i will...i know i have 94 around here.
well i don't remember before my accident, it feels like years since i've had my car. but as for yesterday it was a bit cold outside and the idle was a bit jumpy...not jumpy over 1k rpm but in between 750 and 1000 it was rough and jumpy...is that normal with all Foci?
Thanks again.
