There seems to be another recall (at least here in Canada) called #00T04. Something to do with low temperatures and the PCM.
I thought I would summarize the problems I have had with my 2000 Focus (16,000km, 1 year old). Sad to say, but I will probably be selling my car in another two years. I can't imagine what else might go wrong when it has aged a bit:
1. Metal on metal grinding sound from the rear wheels. Very worrisome[Not Fixed Yet]
2. Warped front disks. [Not Fixed Yet]
3. Broken oil cap. The technician busted it the last time I had the oil changed. [Not Fixed Yet]
4. Service #00B59. Clutch master cylinder and return spring replacement. [Not Fixed Yet]
5. Front suspension creak. [Not Fixed Yet]
6. Upper body cladding is bending/warping outwards near the door handle. [Not Fixed Yet]
7. Recall #00T04 PCM Engine management recal [Not Fixed Yet]
8. Rear seat recall #00S55.
9. Clutch spring broke after 2 months.
10. Rear wheel recall #00B59.
11. Trim piece recall #00S20. [Not Fixed Yet]
12. Sqeaking rear brakes needed lubrication on the backing plates.
13. Broken shifter boot.
14. Mis-aligned drivers side door.
15. Cracked rocker moulding. [Not Fixed]
Stock '00 ZX3, 5sp, A/C, RF Green
[This message has been edited by tomp (edited 04-11-2001).]
Linear Mode
