Ford Racing Performance Parts
Old 04-28-2001, 08:50 PM   #1
jmdavid
Default rust on front brakes?
i've noticed some rust on the front brakes. is this normal for disc brakes? i've never had a car w/ disc brakes before.
jmdavid is offline   Reply With Quote
Old 04-28-2001, 09:44 PM   #2
Bobby
Default Re: rust on front brakes?
Yes, it is normal because the rotor is just bare metal.
If you are going to show your car off to friends, just ride the brakes a little before you get there and the pads will scrape the thin film of rust off.
Don't worry about it; it's normal.
Bobby is offline   Reply With Quote
Old 04-29-2001, 11:59 PM   #3
MidnightZX3
Correct me if i'm wrong but are you talking about the rust on the calipers? I have the same problem. Looks ugly as heck so i think im gonna paint them
Midnight Black ZX3,
35% tint,
Kicker Impulse 15's
Quote from best friend;
"Are my ears gonna keep ringing all day!?"
MidnightZX3 is offline   Reply With Quote
Old 05-01-2001, 03:36 PM   #4
JonBoy470
Rust on rotors is normal. Our Foci have nice wide-open wheel designs, which simultaneously make the problem worse (more water gets to the rotors) and more noticable (you can see the greater amount of rust through the wide-open wheels.)
The rust is a very thin layer, and is generally ground off within the first couple of minutes of driving. As Bobby indicated, a purely cosmetic problem.
-Jon
2k ZX3, Infra-red, auto, air, cruise, tilt, pw/pl/pm, abs, var. int. wiper conversion, Sylvania XV headlights
IM: JonBoy470
JonBoy470 is offline   Reply With Quote
Old 05-03-2001, 04:19 PM   #5
01sportwagon
You can paint the calipers with High Temp paint (like BBQ paint), anything else will burn off. But don't paint the rotors. Or rather don't paint the friction surface of the rotors, the part that touches the pads.
01sportwagon is offline   Reply With Quote
Old 05-03-2001, 05:03 PM   #6
silver_bullet
jmdavid, I'm curious... what kind of car were you driving that had no disk brakes? I haven't seen a car with drum brakes up front in years!
silver_bullet is offline   Reply With Quote
