Go Back   The Ford Focus Forum | Powered by Focaljet > Vent about your Ford Focus > Problems/Service/Recalls
Old 07-03-2001, 07:55 AM   #1 (permalink)
Default Hand brake
How far up is your handbrake travelling. When I put mine on it seems to go up 7/8 clicks. It also sounds as it is clunking as i reach tention as if it at it's limit. Just curious to know what other peoples is like as this doesn't sound like normal.
Griff
Griff is offline
Old 07-03-2001, 10:43 AM   #2 (permalink)
Default Re: Hand brake
That sounds about like mine. I'd prefer 3 or 4 clicks. I am going to look at the Ford CD and see what it takes to tighten it up, someday. But I think yours is 'normal'.
blurr is offline
Old 07-04-2001, 10:30 PM   #3 (permalink)
Check rear brake adjustment mine was very loose at 1,000 miles
whitesedan is offline
Old 07-05-2001, 08:41 AM   #4 (permalink)
the e-brake adjustment screw thingy is under the center console...
Take out the center console (if you are the adventurous type and don't have probelms taking your car apart) and you will see the adjustment screw where the cable engages the e-brake assembly.
If you don't want to mess with it, take it in to your dealer and have them tighten it. Problem is, most dealerships do not have "installers" working for them. When it comes to taking out panels/consoles/anything from inside the car and not under the hood, a stereo shop with "installers" is a much better place to take it.....
Kelric is offline
Old 03-30-2008, 11:50 AM   #5 (permalink)
Newbie
Hi -- My 2004 ZX3 has a loose praking brake meaning I pull it 7-8 clicks and it barely will hold on level pavement -- on any grade, it is completely ineffective. Are you telling me that if I remove the console (all the covering around the parking brake lever, that I will expose an adjustment screw? Mechanics I have asked have said the place to adjust this in in the rear brake assembly. I would love to find that the adjustment to tighten the paking brake is in the console.
focusfather is offline
Old 03-30-2008, 03:00 PM   #6 (permalink)
Official [FJ] Spam Police Chief
Ok-- here is what to do. First try using the auto adjuster. Yank the ebrake about 20-30 times in a row.
If this has no effect, you can use the adjuster screw. This is located under the ebrake boot. Just unclip and lift the boot up to expose the screw. You do not want to make it too tight--- IIRC the spec is something like 30 lbs of force to reach 5-6 clicks.
If you still can't get it to work right, it may be time for that trip to the dealer.
Originally Posted by sicko
I just need to be able to tap it :(
I've done if from underneath before but can it be done at any other angle?
Qwik1 is offline
Old 04-02-2008, 10:14 AM   #7 (permalink)
Yes, pop the console out. It's 2 phillips screws under the front cup holders, then pop out the rear cup holder insert (squeeze to get the back tab out and then pull up) and then it's 3 10 mm bolts holding it in. Lift the back up (pop out the shifter skirt first, you don't have to take it all the way off) and carefully remove it. It should be fairly obvious after that.
Hope that works!
2004 Black ZX3 Zetec
BAT springs,Ford Racing short shifter, Falken RT 615 205/50/15
Underdrive pulley and shorty header, H&R 5mm spacers and hardened lugs, Hawk HP+ front pads, SPC camber plates
Up next short term: Replace header, timing belt and water pump
Up next long term: cage and Rally Spec Focus!
Silonius is offline
Old 04-04-2008, 11:03 PM   #8 (permalink)
I'm pretty sure a shop just cut a little slit in the boot of my brake to tighten it up. if you can find the screw that would be the easiest method. I'm not complaining, they did it for free without asking
2003 PZEV SE sedan
MM CAI, H&R Race springs, Koni yellows, Auto-x-ZTS 24mm rear swaybar, SPC camber plates, Poly FLCA, VF Rear engine mount, 15 x 7.5 Rota Slips, Toyo R1R
RIP 2001 Infra-Red Street Edition Sedan
I want an SVT Focus is offline
Old 04-06-2008, 12:42 AM   #9 (permalink)
ZX3autoxtasy's Avatar
http://www.focushacks.com/index.php?modid=81
Your welcome.
2008 Specialized Tarmac:: 0.0mpg with more carbon than your Focus. Pure. Power.
2007 Ridley Crossbow: Beware. Terrorizing you town until I sell it for a TT bike.
2004 Pitch Black 5spd 2.0L(Z) ZX3: Eibach Pro-Kit Springs, Eibach Pro-Kit Dampers, Brembo Rotors, Hawk HPS Pads, H&R 24mm Rear Swaybar, P-51 Shims, Focus-Sport Cool-Flo, Focus-Sport front & rear stress bar, MBRP Cat-Back, [Track] 15'' Steelies with 205/50/15 Falken Azeni RT-615's,[Street]UK ST200 Mondeo Wheels w/ Toyo Proxes 4 215/45/17's, Quantum Audio 12''/Quantum 800w Amp, Custom Ported Box, SVT Lip, and tons of other stuff...
ZX3autoxtasy is offline
Old 04-06-2008, 04:05 AM   #10 (permalink)
Why do the totally unnecessary work of pulling the console? At least try it by just pulling the boot up. I have done this on several Foci, and never had to move the console.
Qwik1 is offline
Old 11-02-2009, 09:42 PM   #11 (permalink)
Exactly! Just remove the E-Brake boot (it snaps out) to gain access to the 10mm adjustment nut. You're welcome!
2001 Sangria Red ZX3
fruitport_focus is offline
