James Barone Racing
Results 1 to 10 of 10
    Senior TEAM Member G1-Focus's Avatar
    Dec 2000
    Greenwich, CT
    1,087
    Default Washer Fluid Reservoir Leaks/Overflows
    I know this has been addressed previously.
    I fill the reservoir and it leaks out either on to the ground, which you can see if I enter or exit while in a curve (at slow speeds in and out of a driveway), or it leaks back into the engine compartment and trickles down under the battery tray and the intake box is sucking some of it in and I'm getting blue crystallization forming below the air-filter inside the air box.
    I remember that people had posted that earlier versions had a reservoir with a 'second opening' that wasn't supposed to be there or was supposed to be sealed but wasn't.
    Thanks.
  2. #2
    Feb 2003
    SLC
    446
    Default Re: Washer Fluid Reservoir Leaks/Overflows
    Thanks.
    <font size="2" face="Verdana, Arial">I just noticed this on my car a few days ago. I filled it with an entire gallon of juice, and drove around for a while. When I got home, I saw some liquid near the drivers side of the engine. I put a towel in there, and it soaked up a ton of wiper fluid. I'm going to take it in for warranty work soon.
    Has anyone else experienced this?
  3. #3
    Apr 2001
    Newton, MA
    496
    Hah that's not so bad. I had removed my intake resonator, and one day removed my air filter to realize a bunch of green...it had been sucking washer fluid into the engine! Haha well that's the real reason behind my home depot intake.
  4. #4
    Aug 2000
    Chicago, IL, USA
    130
    <font size="2" face="Verdana, Arial">I just put entire gallon of fluid in yesterday and the little cup thing was still empty. Isn't the thing you pour the fluid into supposed to show how full the resevoir is? [img]images/icons/confused.gif[/img]
    How much does the resevoir hold? I wonder if I have leak or something too? I couldn't tell because I spilled some when starting to pour.
  5. #5
    Feb 2003
    SLC
    446
    Well, It was a gallon and then about a cup of water from the sink. I wanted to see how much it could hold as well. Is your's leaking too?
  6. #6
    Feb 2003
    honolulu, hawaii
    25
    mines leak too. i want to change the seal.
  7. #7
    Jan 2003
    SE Wisconsin, Twin Lakes
    2,778
    All I know is I put an entire gallon in and a week later, it was empty, I mean none left. And I know I hadnt used it. [img]graemlins/thumbdown.gif[/img]
  8. #8
    Feb 2003
    SLC
    446
    I dropped off my car at the dealership this morning, and I just called the service manager. He told me that this was normal, and that the reservoir leaks. It isn't airtight, and if you fill it pretty full, some will splash out. I really don't want to believe this. Does anyone know how I can contact Ford directly to get a straight answer?
  9. #9
    Aug 2000
    Chicago, IL, USA
    130
    The manual says it takes 4.2 quarts of fluid so a gallon wouldn't fill up an empty resevoir.
    If I really feel motivated I'll take off that plastic inner fender cover and look at the resevoir and see if it's leaking, but I don't think mine is.
  10. #10
    Feb 2002
    blasting across the alkali flats in a jet pow
    172
    Not the same issue, but I noticed on 2 occasions last summer, if I filled it on a really hot day, it would actually trickle out off the nozzles a little bit.
