Grassroots Motorsports
Old 03-06-2006, 05:00 PM   #326
rskona
Default Re: Please post if your ignition has locked!
I've had it happen 3 times! only good thing about it was, that it was replaced under warranty. it seems to happen every 20 months
rskona is offline   Reply With Quote
Old 03-07-2006, 01:32 PM   #327
logistiker
I found it. Go to a locksmith who deals with cars and tell him you want to change out your ignition cylinder with Strattec part #707592. The locksmith I went to said he could file down the old cylinder so that metal rod doesn't stick out anymore and jam it but I didn't care to mess with it. I just had him change out the whole cylinder with the Strattec part. Incidently the Strattec part doesn't even have anything that could possibly cause the cylinder to lock up anymore like the POS ford part. I consider this a permanent fix.
logistiker is offline   Reply With Quote
Old 03-07-2006, 01:53 PM   #328
rleiato01
If mines kinda gets stuck once in a while and I have to pop it out with my finger, does this mean mines is gonna lock up soon? I hope not...
04' Gray SE Sedan w/18" Enkei Adam Saruwatari wrapped in 215/35/18 Dunlop Sports, Drilled and Slotted Rotors and painted rear brake drum, Custom Catback Exhaust, Mac Short Ram, Focussport Race Headers, Ford Racing Ignition Wires, Eibach Sportlines w/Pro Dampers, Optima Yellowtop Battery, Autometer Carbon Fiber Oil Pressure and Volt Gauges, Mach HID's, Streetglow Blue Washer Nozzles, Blue Neon Tubes In Trunk, Interior and L.E.D.'s in AC Vents, Tinted Grille, Clear Bumper Lights, Custom Shorty Antenna, Custom Blue Painted Interior, Alpine IVA-D310, Kicker KX650.4, Rockford T20001, Rockford 3Sixty.2, Digital Designs 9515F, Diamond Audio D6 5.25 Components and Infinity 5x7 Coaxials and Clifford Alarm to protect it all...
rleiato01 is offline   Reply With Quote
Old 03-08-2006, 03:49 PM   #329
rskona
thanks........
Old 03-12-2006, 04:41 AM   #330
247_racing_zx3
glad to hear i wasn't the only victim. Mine just happened today....Going back to the car and trying to get it to work so i can take it home, its currently 5 minutes away from my house stuck at the pool hall -_-
247_racing_zx3 is offline   Reply With Quote
Old 03-12-2006, 12:34 PM   #331
247_racing_zx3
temporary fix by lubing up the key putting it in and out of the key slot, then banging it into the keyhole with alittle bit of force, it got the tumbles loose and i was able to turn the key. Now i need to find out a way to completely remove the lock cylinder and replace it with a bunch of switches.
Old 03-13-2006, 08:55 AM   #332
SaTaNcLaUz
oh man, i just had the thought in my head of a series of 10 rocker switches that you have to have in a certain order (think DIP switch) before the car will start
that would be kinda cool actually
SaTaNcLaUz is offline   Reply With Quote
Old 03-15-2006, 05:42 AM   #333
247_racing_zx3
it would be just like a race car. I called a guy i know that works in the Sunnyvale CA, ford dealership. I have an 2003 w/ 28k miles, he said not to worry and im still covered under warranty. He told me that he'll talk to the technician if they try to give me crap about having to pay $280-$300 for a replacement.
Old 03-24-2006, 10:00 AM   #334
punklife04
Mine is locked up in my driveway now!!(just glad it's not somewhere else) I was going to attempt replacing it myself but since I cannot get the key to turn I can't hit the pin to pull it out. Guess i'll try busting out the lube!!
Used to like ford's but this Focus has been nothin but problems.
punklife04 is offline   Reply With Quote
Old 03-24-2006, 12:44 PM   #335
CatMostFeared
add me to the list locked up on at home twice.
[b]2000 Turbo WRC ZX3
CatMostFeared is offline   Reply With Quote
Old 03-29-2006, 03:42 PM   #336
Adam777
This happened to mine a while ago. Just though I would add myself to the list. I paid like $400 to get mine fixed. Hopefully the new one is improved.
Adam777 is offline   Reply With Quote
Old 03-29-2006, 10:24 PM   #337
CatMostFeared
cost me $80 and about 2 hrs labor,had to drill the old one out.
Old 03-31-2006, 04:05 AM   #338
yescaman33
mine locked up about a week ago.
2003 Twilight Blue ZX3
Powerworks s/c, f/c 65mm t/b, jba shorty header, r/t high flow cat, f/c flex, borla exhaust, f/c cam gears, f/s wires, spec stg 3+ clutch, f/s flywheel, Torsen lsd, f/c short throw shifter, vogtland springs, kyb agx shocks/struts, eibach front and rear swaybars. 219.1 hp 184.9 tq
yescaman33 is offline   Reply With Quote
Old 03-31-2006, 09:31 AM   #339
Raybies
Newbie
My wife has 67,000 miles on her car and we have had to replace the ignition 3 times. Ford knows about the problem but hasnt ever issued a recall for this pronlem.
Raybies is offline   Reply With Quote
Old 04-05-2006, 03:12 PM   #340
fm-corey
Thumbs up Re: Please post if your ignition has locked!
had it happen a to me few weeks back, cost me $160 for a locksmith to rekey the new lock cylinder to my key, ford had quoted me $500+ plus towing .. the locksmith had also told me that this new ignition cylinder is of different manufacturer and will not fail me again.. so far its been much better than the 06 focus cylinder i have used so i believe that this aftermarket unit that is far superior to fords OEM design , remeber to check out locksmiths if you are ever in this situation...
fm-corey is offline   Reply With Quote
Old 04-06-2006, 01:45 PM   #341
blackhatch46
me too, thank god it was still under waranty...
blackhatch46 is offline   Reply With Quote
Old 04-09-2006, 04:20 PM   #342
StealthFocus
Happened to me a couple weeks back at 190,000kms.... Wasnt too upset since i could always get the key to work after 2min of trying (with WD-40)
But please people.... do not pay to have this done... it is extremely easy to repair.
There is a post on here with a how-to for getting the cylinder out and there are instructions in the box the part comes in... you need minimal mechanical skills and grade 3 math to fix it. SUPER SIMPLE
2001 ZX3 Pitch Black 5 Speed
Mods: 16 Cougar rims painted Black, Ground Control coilovers, Koni shocks/struts, FULL Prothane bushing kit and Motor mount, FS Coolflo, FS Exhaust, FS Flex pipe, FC 4-2-1 Race header, Crower Stage 2 Cams,FC 65mm Throttle Body, Kent Cam Gears FS Plug wires, FS Strut Bar, AFX UDP, KKM WRC Wing, MC Rallying WRC Front Bumper, Hella indicators, Euro upper grille, Cross Drilled Rotors, Mintex pads, Gutted Hatch
StealthFocus is offline   Reply With Quote
Old 04-09-2006, 04:59 PM   #343
Focci01
Uhhh can i join the list happend Twice on my car
www.focsa.net
Focci01 is offline   Reply With Quote
Old 04-20-2006, 10:34 PM   #344
Bleed Blue
Newbie
Yesm my ignition went out at 50,000 miles, and cost $250 at the dealership. It is about to go out again, too, as it dragged enough to destroy the starter motor (80,000 miles), and if I had not had a friend of mine do the work at his own shop, the bill would have been a lot more than the $360 he charged. It probably would have been my fault at the dealer, as well, for damaging the starter.
I hope to get some serious mileage out of this car, and I own a lot of Fords, and have always had one as a daily driver, as well as the current older stuff I own. My brand loyalty may soon go away, though, if Ford doesn't offer some sort of help or apology for this. Think of the kids that are buying their first cars and get stuck with these types of problems. Its enough to make me think of selling off some Ford stock. As it is, I may think of a Toyota...
Bleed Blue is offline   Reply With Quote
Old 04-25-2006, 01:47 AM   #345
Deborah
Newbie
I have a 2001 Focus SE. This has happened to me twice within the last 3 months. First time, AAA came out and the gentleman knew exactly what I was talking about; stating they get calls on this problem all the time. The second time happened to me today. I called the nearby Ford Dealer to see if there has been a recall and I was told there was not. Then I asked what the cost would be to repair it and I about fell over when he said $399.
I had my car towed to a friend's workplace and went to a couple automotive places thinking I could have my friend replace it for me. I could not even find a automotive place that carried the ignition cylinder; I was told it was a dealer only item. If anyone knows of a place that carries this, I would appreciate the info.
Deborah is offline   Reply With Quote
Old 04-28-2006, 08:57 PM   #346
lignamus
Newbie
My ignition has locked and I'm pissed.. . I cant belive this. I drive a sm car to save on gas then this happens. Now they are telling me that it might not be covered. WE NEED TO DO SOMETHING!!!!! The dealer told me that this is a on going prob with the focus... HUMMMMMM why doesnt FORD do a recal??? AARRRRRGGGGG!!!!!!
The bad part i got stuck with my 2y 4y 7g girls in the car at the store...
2003- focus
lignamus is offline   Reply With Quote
Old 04-29-2006, 03:28 AM   #347
LikwidZX3
well, just lurking around after a couple year absence and saw this thread.
My ignition locked last year. Lukcily my father in law is handy and fixed it for the price of a new ignition. The dealer said it is happenning very often. Not sure why no recal yet?
2000 ZX3 Cloud 9 White
Check It Out Here
All Your Foci Are Belong To Us
LikwidZX3 is offline   Reply With Quote
Old 05-01-2006, 12:51 PM   #348
Focci01
Some guy in Kingsville, Tex got his locked up at a meet
www.focsa.net
Old 05-03-2006, 08:44 AM   #349
ubersput
Mine (zx3 2001) locked Christmas time as we were traveling to see the family. Was not funny (cold wather). Called tow truck twice each time the service person spend 1/2 h and finally got it to start but ath the dealer thay could start it to move into the service area...so they had to work in the cold outside. Paid around $300 (my Extended Warranty did not cover it).
ubersput is offline   Reply With Quote
Old 05-09-2006, 10:22 AM   #350
stuckignition
Newbie
I had the same problrm today. It is so annoying. I can see why Ford is going bankrupt. Losers!!
The deelership is asking 470 dollars and 4 hours.
A private mechanic tell me 270 and 2 hours.
Man I hate being victimised!
stuckignition is offline   Reply With Quote
