Tire Rack
Old 03-04-2007, 04:52 PM   #1
lm1d
Default Erratic idle w/ A/C?
My daughter has a 2.0 duratec, 2000 ZX3. The car idles erratically when the A/C compressor runs, it idles fine when it is off. The idle moves to 2000-2500 and back when the a/c switch is on, it seems to not matter whether or not the compressor is running.
When the a/c is switched off, everything is fine.
Any thoughts? Can't seem to find much by doing a search.
Thanks!
lm1d is offline   Reply With Quote
Old 03-05-2007, 01:03 AM   #2
MadDawg-Zx3
Default Re: Erratic idle w/ A/C?
hmmmm I was thinking maybe an IAC concern but it only happens when the A/C cycles. That stumps me.
maddawg
MadDawg-Zx3 is offline   Reply With Quote
Old 03-05-2007, 12:58 PM   #3
MEJ684
Isnt the a/c system controlled by vacuum? Im thinking a vacuum line is off causing the crazy idle spike.
What is the idle like with the a/c off? Normal it should be around 750 rpm.
-Mike
MEJ684 is online now   Reply With Quote
Old 03-06-2007, 01:26 PM   #4
lm1d
I can unplug the pressure switch under the right front fender, the compressor quits cycling and the idleing stops. Does anyone have a troubleshooting chart for that pressure switch? I think it's a high/low switch because it have 4 wires in it.
Old 03-07-2007, 02:04 AM   #5
MadDawg-Zx3
is the A/C cycling on and off every few seconds? If it is and the Fans are staying on you need to replace the Switch
maddawg
Old 03-08-2007, 11:50 AM   #6
lm1d
Yes, a/c is cycling every few seconds @ idle. I can't seem to find one with 4 wires, only 2. Guess I'll have to go to the dealer.
