North Coast Performance
Old 02-09-2007, 07:19 PM   #1
joementum
Newbie
Default Keys STUCK in ignition.
Ok don't know if this is related to the thread below, my key can not be removed from the ignition. I'm worried that this may be a first sign leading to the ignition locking up.
It's not the steering wheel being turned to a side.
Should I simply leave the key in and lock the doors w/ my spare key?
anyone have a cheap fix?
joementum is offline   Reply With Quote
Old 02-09-2007, 07:58 PM   #2
Foci_Fosho
Default Re: Keys STUCK in ignition.
happened to my friend.... who's name also happens to be joe.
ended up getting a tow to the dealer and a ignition cylinder replaced under warranty.
Old 03-04-2007, 08:19 PM   #3
jeange
Newbie
ya that happen to my sister the day after she bought it. The simple fix was to push the shifter to make sure it is all the way to the forward position in park if your car is automatic that is. If its not then I dont know. But try making sure the shifter is pushed as far as it will go.
jeange is offline   Reply With Quote
Old 03-05-2007, 01:02 AM   #4
MadDawg-Zx3
that has nothing to do with the Key Cylinder locking up. There is a new TSB for this and we ed up replacing the Shift Interlock for the trans. Basically it wont let you remove your key unless you car is all the way in Park. Thats what it is. No need to worry
MadDawg-Zx3 is offline   Reply With Quote
Old 03-10-2007, 07:14 PM   #5
orionlion82
WARNING: This post may be hazardous to your health.
i get it. nm.
orionlion82 is offline   Reply With Quote
