The operation was a Success. I did not remove the tumblers, I Just removed the lock bar that rides on top of the tumblers. I found the second tumbler from the tip of the key was sticking and not lining up with the rest. I reinstalled the lock with out the lock bar, it does not jam anymore. Then I did some testing. I started the car with no problem, them removed the key and got out of the car, it still ran as I moved 20+ feet away. Then I put the key back in and turn the engine off. Then I tried the key from the 88 Stang, I put it in part way only so it would not get stuck, then try to start the engine, it did not start proving the PATS system works. It was easy and only took about 45 Minutes to do it for the first time. One nice thing is I can run the engine when its cold out and take the key with me inside. I think I'll wait to spring to replace the lock.
One more Thing, If you do this Temp Repair remember to remove the ground wire from the battery for safety.
I have to thank GOD and All of you on Focaljet and FF, you all saved me some money. Thank You.
