Tire Rack
Old 07-07-2008, 12:58 PM   #1
sparty0008
Default hesitating engine when i have a 1/4 tank of gas
latley my 2000 focus (155,000 miles) starts to bog down and somtimes stall when i have a 1/4 ( or slightley under ) tank of gas can anyone help?????
sparty0008 is offline   Reply With Quote
Old 07-07-2008, 01:16 PM   #2
RallyRacer
Default Re: hesitating engine when i have a 1/4 tank of gas
Time to replace the fuel delivery module (fuel pump). Very common problem with your year and mileage.
This is a recall on most 2000-2001 Focus, so check your dealership first. In fact tell them you know it is a recall and describe the symptoms. They will most likely replace it for free under the recall.
2001 ZX3 Infra-Red, Auto
Power: Volant Ram Air, 65mm FC TB, 2000 ported intake, SVT header, Random ORP, Bosal flex, Borla exhaust, Esslinger UDP, FocusSport Xcal2(FR stage1 cams and gears to be installed)
Handling: Energy bushings everywhere, Koni Adjustable dampers, H&R sport springs, SVT rear swaybar, FC rear toe links
Braking: SVT brake kit, Hawk HPS pads F&R, Aeroquip braided lines
RallyRacer is offline   Reply With Quote
Old 07-07-2008, 05:24 PM   #3
sparty0008
Thank you for the information....It is in the shop as we speak.
Old 07-09-2008, 06:51 PM   #4
jenhappy
It's extended warranty program 03N01, but it won't come up as a recall, so you may have to mention it to them depending on how well their system is checked/updated. The program started in Nov 2003, but I think some dealers either aren't keeping up with these programs, or are purposely ignoring them... who knows which.
jenhappy is offline   Reply With Quote
Old 07-28-2008, 05:00 PM   #5
sah26
Just mine replaced at the dealer about 3 weeks ago. No charge to me on my 2001. Just make sure that they actually reconnect the filler tube on the car so that you do not spill gas everywhere, esp when you are paying $4.00+ per gallon.
sah26 is offline   Reply With Quote
