Hi,
My girlfriend's 03 Focus ZTS 5spd, stalled out on her this weekend in traffic, and would not start.
Here's what I've done:
-The engine turns over freely, but no spark coming from the coil.
-Had the coil tested by a ford mechanic, says it works fine, but has a couple cracks and should be replaced. I picked up a functional used coil for testing, but nothing coming from it either
-Used a multimeter to check voltage from the harness plug into the coil pack. No voltage from all 3 wires when engine is being turned over
-Used a SnapOn scan tool to scan, came up with P1000 and P1709 codes. The 1000 is a nothing code I think, and the 1709 is a CPP/EPM code. Since the car turns over fine, I can't see there being an issue with the clutch switch (CPP)
SO, I am totally lost, not sure where to go from here. I would greatly appreciate any advice or recommendations. I hate the dealership and the girlfriend doesnt make a lot of money so I'm hoping to figure this out on my own. Thanks a lot
Linear Mode
