Go Back   The Ford Focus Forum | Powered by Focaljet > Vent about your Ford Focus > Problems/Service/Recalls
Old 11-21-2008, 08:41 PM   #1 (permalink)
Default HELP!!!! Cant remove my key!!!
My 00 focus ATX wont let me take the key out of the ignition. I can put it in park, but the shifter wont lock in place so I cant remove the key. Help!!!!
Thanks
***Fast toys ain't just for boys***
Powered by PowerWorks
focuschic316 is offline
Old 11-22-2008, 08:31 PM   #2 (permalink)
Default Re: HELP!!!! Cant remove my key!!!
Try moving the shifter back an forth a fes times and see if it locks.. if if doesnt you may have to take the console apart and make it click into place manualy.
Cookieman00x is offline
Old 12-06-2008, 09:13 AM   #3 (permalink)
Common issue with that generation. Find a way to get it out. If you can, then you will need to replace the ignition cylinder by drilling it out. I think I paid ~$70 for one from a locksmith and spent 2 hours drilling the old one. Else you'll get stuck with a hefty bill from a locksmith or dealer. This issue is posted in multiple places on this forum. It's how I learned and did this last spring to a 2000 model.
dsgrey is offline
Old 12-07-2008, 09:35 PM   #4 (permalink)
move the shifter all the way up and down. if that don't work, use a little more force. don't break it, use common sence
MonkeyGein------>GO TO THE 507 --------------------------m-------m------
For Sale: 2007 Salvage ZX3 or any part off it. . . . . . . . . | |(o O)| |
http://forums.focaljet.com/vehicles-...le-07-zx3.html . . . .|| (~) ||
MonkeyGein is offline
Old 10-23-2009, 06:26 PM   #5 (permalink)
Newbie
I found the shifter boot slides down a bit and will not allow the mech. fully into "park", by sliding it back up, the problem was resolved.
Anthony1 is offline
Old 11-15-2009, 12:34 AM   #6 (permalink)
Newbie
Flick the shifter button. The button on the side of the shifter pushes a rod down that makes a switch under the shifter. When the rod does not spring back up, the switch electrically prohibits the lock cylinder from turning completely to release your key.
mnwrench is offline
Old 11-15-2009, 05:58 AM   #7 (permalink)
Newbie
had the same problem with my 03 zx3....if you are still able to turn your car on i would just take it to a mechanic, its wat i did. Apparently once this happens the key cylinder needs to be replaced and if you still have the key in place you dont need to drill it out, so its cheaper to fix
pagany64 is offline
