Go Back   The Ford Focus Forum | Powered by Focaljet > Vent about your Ford Focus > Problems/Service/Recalls
Old 10-15-2009, 04:22 PM   #1 (permalink)
Default Engine surge
Hey guys, I need some input on a problem I am having on my 2000 Focus LX. I notice that sometimes when accelerating from a stop, my engine's RPMs will surge unusually high as I apply pressure to the gas pedal. This will happen before the power seems to kick in at the wheels. It's as if I am revving it in neutral, then throwing it into drive. It also seems to take slightly longer than it should to decrease the engine's RPMs, when I go to apply the brakes to stop. Almost like a delay. It would do this intermittently, and just recently it has seem to have become worse. The "CEL" has also come on and will not go off. I don't know if that is related to the issue at hand but do these symptoms sound familiar to anyone? What are they usually indicative of?
Brock Samson is offline
Old 10-15-2009, 07:27 PM   #2 (permalink)
I <3 UC^3
Default Re: Engine surge
I would get the code read first. Autozone or similar can usually do that for free. Having the code will give you a place to start.
Tuned By: Bristol Dyno
hEaT is offline
Old 10-16-2009, 06:19 PM   #3 (permalink)
Ok, got the code and it was a P1405. It seems the DPFE or EGR need to be fixed. Is it actually possible to clean them without replacing? Let me know if any of you folks have done this with good results. Thanks!
Old 10-31-2009, 05:25 PM   #4 (permalink)
just replace the dpfe its prolly the problem also when ur traveling 40ish does it seem like ur in a strong headwind?
i <3 my fofo
Originally Posted by cobrawannabe cdw27 View Post
Have you any experience with this mod on this car? Apparently not.
bwatt is offline
