Go Back   The Ford Focus Forum | Powered by Focaljet > Vent about your Ford Focus > Problems/Service/Recalls
Old 10-17-2009, 02:51 AM   #1 (permalink)
Newbie
Default Common Focus Problems
Hello everyone I just purchased my first ford (2001 Ford Focus ZX3) and joined this site in hope of learning all i can about my Focus so I wanted to start a thread of all the common Focus problems out there, that way we can prepare for battle in the garage and maybe catch something before it happens.
Id like to start off with the ones I'm facing now......
1) Valve Cover Gasket (eh easy fix)
2) Cooling Fan not working (from what ive read on here so far it seems to be the cooling fan resistor,or maybe the CHT is the culprit, maybe even the wiring harness) not sure yet?
3) Hood latch handle (mine is broken off)
4) Ball Joints (clicking noise on hills, i know there's a recall on them)
n1ghtfl1ght is offline
Old 10-17-2009, 03:34 AM   #2 (permalink)
Terry1's Avatar
Default Re: Common Focus Problems
Motor mounts
T-stat housing ( because of valve cover leak )
Ignition cylinder
Wheel bearings
Terry1 is online now
Old 10-17-2009, 05:15 AM   #3 (permalink)
thermostat housing
alternator
blower resistor
singleparin is offline
Old 10-20-2009, 04:36 PM   #4 (permalink)
frdfocszx3's Avatar
All of the above plus the fuel pump.
2009 Impreza WRX
1991 Toyota Chaser
2000 Focus ZX3 (sold)RIP
frdfocszx3 is offline
Old 10-22-2009, 12:03 AM   #5 (permalink)
I <3 UC^3
Dpfe
Tuned By: Bristol Dyno
hEaT is offline
Old 10-22-2009, 01:02 AM   #6 (permalink)
20focus03's Avatar
pcv hose collapsing,rear drums squealing like all hell
03 Sangria Red zx5 stock :)
09 Harley Sporster 1200 :)
99 Yamaha R6 (stunter) :)
93 S10 -SBC in the works :)
._________________________
|.....Overnight.....................| ||
|........Japan Parts................||'|";,___.
|_..._...____________======||_|_|...,]
20focus03 is offline
Old 10-23-2009, 12:28 PM   #7 (permalink)
01slo-cus's Avatar
The most common ones I've seen or had happen:
-shifter housing breaking if you have biceps larger than a 5yr old girl
-leaky thermostat housing
-DPFE sensor (part of the egr system)
-Wiper motor (was a recall- mine croaked-easy fix though)
Other than that my car has been very reliable. I have well over 150,000mi on the original engine, tranny, clutch, cv shafts, ball joints, wheel bearings, fuel pump, alternator, battery, ect., ect.......
2001 ZX3 CAI, ported TB, SVT header, UDP, 2.5" exhaust and still barely gets out of it's own way!
01slo-cus is offline
Old 10-25-2009, 03:51 AM   #8 (permalink)
My foci go through 02 sensors like crazy, and it seems to be a popular thing..
ViperThreat is offline
Tags
common problems on focus
