Go Back   The Ford Focus Forum | Powered by Focaljet > Vent about your Ford Focus > Problems/Service/Recalls
Old 10-27-2009, 05:50 PM   #1 (permalink)
JoshST's Avatar
Question Scraping noise when turning........
Hi,
First time here folks, wondering if any of you can help me, I have searched the previous forums but not found any new suggestions.
The noise happens at slow speeds when turning right, either into driveway or parking space. The noise is located in the front left wheel area and is really loud aswell as really irritating.
Earlier this year I have changed the wheel bearings on the left side and had a new wishbone fitted also on the left side.
It had a problem a few years ago with the steering rack, which I had changed and had checked recently to see if it was that. Just this weekend had new lowering springs fitted and the noise had gone for a little while but came back after going right in a multi-storey car park.
It is lowered 50mm all round with 17" ST170 Alloys on it, it has been on this set up for around 10 years and never had the problem before.
Its quite frustating that its still here, its developed about 4 weeks ago now, ive not changed anything on it to cause it.
Ive looked around the arch and underneath and cannot see anything out of the ordinary.
It is a 2000 1.6 Zetec S (UK) if that helps.
Many Thanks in advance for any advice.
JoshST is offline
Old 11-04-2009, 06:27 PM   #2 (permalink)
Default Re: Scraping noise when turning........
I would check to see if the inside of the fender is rubbing against your tire.
My inside fender clip had fallen off. This caused part of the insides to hang low, so when I turned my car, it rubbed against the plastic.
AJAx is offline
Tags
scraping
