exclamation point light - auto trans problem?
FSWerks
Results 1 to 14 of 14
    May 2001
    Ledyard, CT
    240
    Default exclamation point light - auto trans problem?
    I was cruising normally on a local road in dry weather when the "!" light came on and the car jerked forward..seemed to go out of gear. Then, as quickly as it happened the light went off and the car was fine again...
    what the heck happened? [img]images/icons/mad.gif[/img]
    could this have something to do with my mods, is this just a fluke or is this a sign of something more serious?
  3. #2
    Aug 2000
    Isanti, Southern Canada, MN USA
    2,945
    Default Re: exclamation point light - auto trans problem?
    With it only happening the once, I would say something got confused and went stupid. Keep a close eye on it and make note of anything unusual that happens.
  4. #3
    Sep 2000
    Norwalk, CT
    317
    <blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by noresull:
    ...something got confused and went stupid...<hr></blockquote>
    Gotta love Fords!! [img]graemlins/thumbup.gif[/img] [img]images/icons/rolleyes.gif[/img]
  5. Remove Advertisements
  6. #4
    Oct 2001
    under your bed
    1,535
    [QB]I would say something got confused and went stupid.QB]<hr></blockquote>
    I would say that it's typical of anything mechanical. That's what I think when I work on my computer/bike/car/food...
  7. #5
    Mammoni
    Sep 2000
    10,374
    What I've had happen three times now is the car going 'stupid' with a exclamation for a second, by turning on the high beams.
    Flash highbeams... (!) surge... normal. Flash highbeams again... no problem. Tried playing with the highbeams for the rest of the trip and couldn't reproduce it. But its happened before with the activation of the highbeams and I can't figure it out.
  8. #6
    Jul 2001
    Akron, Oh
    631
    Ihad a tough time starting her this morning. It seemed like it didn't want to start. Then for a split second the ! light came on. It went away and I left for work.
    A few minutes later the car surged like I down shifted or the brakes in the back came on. It was weird. It was light the car went stupid for a few seconds. As fast as it came it went away and the car was fine. I took my chip out and ever since I have had surges from 2200-3000 rpms. What does the exclamation light signify. Any help would be appreciated.
    This only seems to happen in warm weather. Last summer I had the car die while stopped for a stop light, on two seperate occasions. And a few time it took a few cranks to get it to start. Like I said this is only in warm weather.
    Also, only in warm weather, the right passenger side speaker will pop. Like when you are hooking up a speaker when there is a power source. It seems to happen on acceleration. But no pattern, just every once in a while.
    [ 04-02-2002: Message edited by: [\]iteshift ]</p>
  9. #7
    Oct 2001
    hilliard ohio USA
    232
    I have a 5 speed and am having similar problem.I took it to the dealer and they ran a diagnostic chek on the computer and got nothing(no codes)sounds like ford is gonna have some issues coming uo.This seems to be a common problem.
  10. #8
    Sep 2001
    Debi > post whoring
    2,728
    happened to me after a LONG sit at a stoplight with one foot on the brake and the other on the gas getting ready to have some fun, exclamtion point came on, light turned green, car took off faster than I've ever had it go before, didnt get out of first...hit the brakes, light went off.....who knows.....
  11. #9
    Aug 2000
    2,945
    <blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by [\]iteshift:
    <hr></blockquote>
    I have never had any problems with that light, as for the speaker, check your wiring, You may even have a bad speaker.
  12. #10
    May 2005
    arnold, mo
    549
    Quote Originally Posted by HatchbackInBlack
    i know this thread is REALLY old, but i've been having this problem for over a month now, and i can't figure anything out.... does anyone know what could cause this? i replaced the valve cover gasket, spark plugs, and transmission fluid... still having this issue..
    enjoy incubus
  13. #11
    [FJ] Addict GapBoyPCS's Avatar
    Oct 2001
    11,255
    Quote Originally Posted by STLfocus
    It means you need to get that car into the dealer/shop.
    If the light comes on for one time, it's as noresull implied: something went stupid and it should be back to normal. However, if it's on for over a month, it means there is definitely something wrong and you need a good place to find out what it is.
    Since the light is triggered, there is probably a code being stored in the car's computer. If you have access to a code reader or a shop that will do it for free, you can pull the code(s) to see what is being stored. Still, the code is an indication of what may be wrong. Your dealer/shop will have to do their usual diagnostic tests to see what is going on.
    Richard
    2002 ZTS | Sangria Red |
  14. #12
    May 2005
    arnold, mo
    549
    well i've had it scanned by a shop, and no codes are coming up at all.... i've been reading online and it seems that when its happend to other people, they changed their battery cables and the problem was resolved...
    enjoy incubus
  15. #13
    Oct 2001
    11,255
    Have you had the cable replaced yet?
    All the cars that had battery cable problems were notified by mail saying their cars were covered.
    Aside from that, it might be wise in having a good, reputable shop or dealership try and see what the problem is exactly. It may well be the battery cable, but at this rate, you may as well ante up the diagnostic fee places charge for assurance of the exact cause(s) of the problem. It beats throwing in more $$$ for parts that may not necessarily be the problem.
    Richard
  16. #14
    Where is my @#$ antenna?! Honkeytonk Monkey's Avatar
    Dec 2001
    Canadia
    4,107
    Upgrade your ground cable, the wire ford uses is pathetic and I think it causes problems with the amount of voltage getting to the car's brain at certain times. The ZX3 I'm driving right now had stock wiring in it when I got it and if I had the radio up high the car would idle irradically, dropping really low sometimes and other times sticking around 1500. After I replaced the big 3 wires under the hood it stopped and hasn't done so since.
