Mounting amps on sub box
FJ Gear Store
Results 1 to 12 of 12
    May 2004
    Whittaker, MI
    4,105
    Default Mounting amps on sub box
    Is this safe, or can the bass rattle them loose? I have a amp rack thing I fabricated out of sheet metal, but I'm starting to get some vibration from it, and can't pinpoint it, so I think I'm just gonna take it out and mount my amps right onto my sub box.
    Anyone else here have amps mounted this way?
    Help, opinions, and ideas are welcome!
  3. #2
    Aug 2004
    Forest Park, IL
    6
    Default Re: Mounting amps on sub box
    Mounting amps on the sub box is more common then not. Any type of shop will do it for a regular install as opposed to a custom job. Just screw em down tight and if you pull the screws out at any point in time make a note of where they are and either use the same place or caulk them shut so you don't get air leaks.
  4. #3
    Senior TEAM Member SaxManZX3's Avatar
    Jun 2002
    Kissimmee, FL
    2,819
    Dont know if it would cause any problems wih the amp, but it would definitely make things easier to steal. L8er Jon
  5. Remove Advertisements
  6. #4
    Dec 2003
    812
    Amplifier mounting:
    DO NOT mount an amplifier on your subwoofer box. I know that there has been a great deal of discussion over mounting an amplifier to an enclosure and many people do it all of the time with no problems but those people probably build good enclosures from 3/4" (or thicker) MDF with extensive bracing. Most people (especially young impatient people) are too lazy to do that and build unbraced enclosures from 5/8 MDF. These enclosures will flex considerably more than a proper enclosure and will likely cause amplifier failure if the amp is mounted to the enclosure.
    REASON:
    When the woofer(s) moves in or out, the box flexes and therefore causes the sides of the box to vibrate. This vibration is transferred to the amplifier mounted to the box. All of the electrical components in the amplifier have mass. Inertia (an object in motion tends to stay in motion, an object at rest tends to stay at rest) tells them to stay at rest, the box vibration is trying to make them move. The energy from the box's vibration is transferred to the components through the electrical leads which are soldered into the circuit board. All of this will cause the components to break loose and therefore cause the amplifier to fail prematurely. Basically, the amplifier will commit suicide! :-) I'm not telling you this because someone told me it was bad. I've been repairing amplifiers since ~1985. Virtually every amplifier that's come into my shop with parts rattling around inside them have been mounted on the speaker box. It causes the legs of the semiconductors to break (which causes amplifier failure). It causes the capacitors to break off of the board (which can cause catastrophic amplifier failure). It causes solder joints to break on the semiconductors mounted to the heat sink. It causes transformer windings to grind into one another (which causes lots of smoke to pour out of your amplifier). People who repeatedly tell others to mount their amps on the speaker box because they've never had a problem remind me of people who drink and drive and say there's nothing wrong with it because they've never crashed their vehicle. Eventually, in both cases, problems will arise.
    NOTE:
    Mounting the amplifier on the enclosure also allows someone to steal BOTH your amps and speakers at the same time with no extra effort. It's bad enough to have one or the other stolen but losing amps and speakers (and anything else mounted to your speaker box) is really gonna suck.
    Now for those who absolutely have to mount the amplifier to the enclosure:
    NOTE:
    The top of the enclosure has been removed to show the bracing.
    Absolute Worst Situation:
    This diagram shows the amplifier mounted in the center of the largest wall of the enclosure. You will notice that there are no braces under the amplifier's mounting points (red arrows). Because this part of the enclosure will flex more than any other, this will cause more physical stress (from panel flex and vibration) to the amplifier than any mounting position. This would be made even worse because the enclosure has no center brace/divider.
    Somewhat Better Position:
    As you can see, this enclosure has a center brace which will help to reduce panel flex. You should also notice that the amplifier's mounting points are very close to the braces or on top of the wall of the enclosure. These points will have less vibration from panel flex (when compared to points farther from the dividers or walls).
    As good as it gets (with amp on box):
    This method of mounting will relieve most of the stress from the amplifier because the wood braces will connect the top of the enclosure to the bottom of the enclosure and won't allow the panel to flex. The braces should be glued (with a good wood glue) and screwed on both ends. The other mounting points are directly on top of the walls or dividers which will vibrate VERY little when compared to the an unbraced panel.
    http://www.bcae1.com/amplfier.htm
    - Scott
  7. #5
    Jun 2002
    Kissimmee, FL
    2,819
    ^^ does that answer your question?
  8. #6
    Mar 2001
    Still here on certain days of the week.
    1,808
    I gotta tell ya, i have mounted alot of amps to alot of boxes and I have never had a problem. I had one stereo and the amps were on the sub box for 2.5 yrs. Never once did I have a problem.
    I say do what ya want.
  9. #7
    TEAM Member wyc's Avatar
    Jun 2004
    mrrlnd / SE PA
    183
    What about the stock "audiophile" setup with the tiny little amp on the tiny little plastic box? Did I just get screwed royally by Ford?
  10. #8
    Jun 2002
    Kissimmee, FL
    2,819
    Well since its so "tiny", i dont think you will have a problem with a lot of vibration. L8er Jon
  11. #9
    Jan 2003
    Lebanon, PA
    289
  12. #10
    Jun 2004
    mrrlnd / SE PA
    183
    Thanks! I was just curious about the amp and sub that's already on my car.
  13. #11
    Driver > Car
    Jul 2002
    CT
    24,016
    my amps were mounted on my amp rack, which is the top part of my floor enclosure.
    of course, it has 2.25" of MDF bracing underneath on the rails, so it's not that bad. now it's on another tray, however.
  14. #12
    Where is my @#$ antenna?! Honkeytonk Monkey's Avatar
    Dec 2001
    Canadia
    4,107
    It's gooing to depnd entirely on your equipment and the box it's stuck to. I had a n Alpine MRV-T757 screwed to mt sub box for over 3 yars no problems. I never go retarded loud and the amp was well made, so it wasn't a big risk for me. If you're hitting insane db numbers though it may not be a great idea as the vibration and heat generated will add up to a failure more quickly. Basically use common sense.
