Engine flush - good or bad ?
Tire Rack Winter 2015
Results 1 to 14 of 14
    Jul 2003
    P+A+C+I+F+I+C with an +A+
    641
    Default Engine flush - good or bad ?
    Someone please tell me...the pros and cons, I heard both and I'm confused.
    =dRe=
  3. #2
    Apr 2003
    Morganton, NC
    2,572
    Default Re: Engine flush - good or bad ?
    No, bad. It supposedly brekas up all deposits etc. Whare do these deposits go? Into your oil pump pick up and in your oil filter. Plus I have seen some of it turn oil to sludge. Not good.
    Scott
  4. #3
    [FJ] Addict
    Apr 2002
    19,264
    If you're using Synthetic oil.... I don't see a need for this.
  5. Remove Advertisements
  6. #4
    Senior TEAM Member dan-d's Avatar
    Apr 2001
    Sparta, TN
    3,248
    Well it's kinda one of those catch 22 things. If your using a good quality oil (especially synthetics) and have regular oil change intervals there shouldn't be any sludge build up to clean, so running an engine flush compound would probably yield you nothing good or bad. On the other side of the coin is running your oil for extremely long periods (especially dino oil), this will cause a build up of sludge. If the sludge build up is slight then a flush would most likely clean it all out. But if the sludge is heavy it will most likely break the sludge loose, and this sludge will not flow. It will cause all kinds of neat little problems. For one it will plug up the oil pick-up strainer, then any of the smaller particles that may somehow get by the strainer will collect in small oil passages and eventually plug off oil flow. The best way to tell what kind of build up you have if any is to simply remove your valve cover and check for build up on the inside of the head, what you find there is a good indicator of what's in the rest of the engine....good luck.
  7. #5
    Jul 2003
    641
    That's some good advise, dan-d. I f' up my old Civic because I flushed the engine. I did follow the instructions, but a week after I noticed the coolant had some oil inside. Engine stalled numerous times.
    But, like zx3focusguy said I suspected the flush cleaned up necessary build up and the rest...well I'm not a mechanic so I won't try to continue on this
    But, my friend just flushed his civic (113K) and he even used air compressor at end. He saw all kind of sludge coming out and he noticed smoother engine, etc. I guess I will check with him in a month or two
    =dRe=
  8. #6
    Jul 2002
    New Braunfels, TX
    10,540
    mopar has a solution that is similar to ford's BG44. get some new sparkplugs before you do it though. you spray the stuff in and let that engine sit. when you fire it up again it will smoke and smoke and smoke. then all of a sudden it stops smoking. Replace the spark plugs and its good to go, clean as a whistle too. boroscope says A-ok.
  9. #7
    Apr 2001
    Sparta, TN
    3,248
    I don't think we're on the same page. I beleive the author is talking about flushing out the block and lubrication system and not the fuel system and combustion chamber. Completely different ball game.
  10. #8
    Apr 2001
    Sparta, TN
    3,248
    =dRe=
    Thanks!! Just to let you know I do have first hand experience with this. I bought a Mercury Cougar many years ago and when I pulled off a valve cover I noticed quite a buildup of sludge. I put in some engine flush and everything seemed to be working fine, about a week or so later I could the lifters starting to clatter. As I continued to drive the car the clattering got worse, I pulled the valve cover off again and I could see where a lot of the sludge had broken loose, as a matter of fact it had some of the drain holes in the head pretty much stopped up so the head was full of oil and I could tell that the rockers weren't getting any oil. I tore down the engine and the sludge just about completely had the oil pump pick-up tube screen blocked. Engine rebuild time.
  11. #9
    I Now Post Stupid **** Jibberish18's Avatar
    Apr 2003
    Chicago
    3,495
    AUTO-RX
    You'll find out LOTS of info on different flushes from different companies on www.bobistheoilguy.com
    I'm currently using AUTO-RX for my engine, power steering and soon my trans.
    No expert here but from what I hear others say, their is only so much synthetic oil will do.
  12. #10
    Aug 2003
    Camby, Indiana
    1,472
    snyth oil is for preventing a problem IF its ran from day one then you should have no probs and shouldnt need flush. When i got my car it had 40K on it and the lifters were doing a little tap dance so every other oilchange for 2 times i used gunk motor flush and ALLWAYS MOBIL ONE FULLY SYNTHETIC MOTOR OIL IN THE 5-W30 VARIETY. Its light enough to travel well and its mobil one so its the best and its funlly synthetic so its got more vicosity than rosanne has fat grams!!
    from beginning to end I CANNOT EMPHASISE ENOUGH TO USE THAT OIL!!! your engine will give you what you give it. you give it some crappy ass just picked up from the shelf of the dollor store poop and your engine aint gonna live to fight rush hour!!
    and dont forget the weight of a motor oil is important in our engines (all motors nowadays) out motors have holes that critical engine parts rely on oil to flow through them the size of the tip of a pin, bear that in mind
    i have no idea where that came from
    IT WILL NEVER HAPPEN AGAIN*
    *i cannot promise you that it will never happen again
  13. #11
    Apr 2003
    Morganton, NC
    2,572
    This is a very GOOD method IMO. We (Gm dealer) use this quite often especially on northstars with oil consumption problems. But like said, I don't think this is the type of flush he's wanting. Any product made by BG is top notch. I use there complete line of addatives/flushes every day.
    Scott
  14. #12
    Newbie
    Jan 2005
    4
    I freed a stuck lifter once by draining half the oil, adding some Diesel fuel, running it for abour 20 minutes, and then doing an oil change. The previously golden oil was now black.
    If your fuel system can handle it, ethanol-rich gasolines will rid your combustion chamber of carbon deposits. I run E85 in my Tahoe with no problems, but that'a little risky since it's 85% ethanol.
  15. #13
    Aug 2003
    Camby, Indiana
    1,472
    i knew a mechanic who did that. run half oil half diesel then draining, running it again, then draining it , then refilling it with good oil.
  16. #14
    Newbie
    Apr 2013
    1
    A few / several years late to this question but I still found the thread in search so I figured I would toss in my two cents. I see a lot of hate for engine flushes on the internet. It's kind of like buying anything really. If you don't put the research in & just buy what they sell at the grocery store your more than likely going to end up with something that isn't going to be the best for your motor. However, you also have Pro-Tec Autocare which was engineered for mechanics to use during routine maintenance and servicing. This engine flush is certified by the super strict German Technical Inspection Agency & provides superior lubrication during the engine flush procedure. It will increase the old oils lubrication by almost 90% during the flush so their is no cause for concern on lower end bearings. It also breaks down the particles to a small enough size where they pass through traps and screens so no need to drop the pan either. We've tried seafoam as they have been around forever, it doesn't even stack up when compared to Protec.
