My Rear Wheels are not coming off Why?
Tire Rack
Page 1 of 2 12 LastLast
Results 1 to 15 of 27
    Aug 2004
    SW; CT
    104
    Default My Rear Wheels are not coming off Why?
    I have all the lug nuts out, the wheels off the ground, but they're not coming off. Do I just have to pry it off, because I really don't feel like scratching them up. I've never had to do the rear wheels before, but I've been through all this with the fronts and they come off real easy. Am I just forgeting to do something or are they just stuck? I feel like an idiot, but yah, please help
  3. #2
    Oct 2000
    Pennsylvania
    6,298
    Default Re: My Rear Wheels are not coming off Why?
    they're stuck. sometimes they rust to the drum. the other day i had a flat tire and couldn't for the life of me get the wheel off (rear left), no matter how and where i pounded on it.
    so (and if you try this don't blame me if something bad happens) i got fed up and lowered the car with no lugnuts on that wheel, and i slowwwwwly moved the car in reverse for about 2 feet, til i heard a "thunk" and then i stopped. all it did was break the bond between the drum and the wheel, it didn't damage anything at all. not even a scratch in any of the holes on the rim. that was with a stock rim.
    but before you do that, try to just use a rubber mallet or something and see if you can't knock it loose. that was an act of desparation which fortunately didn't end with me breaking anything.
    oh yeah this should be in the Wheels/Tires forum.
  4. #3
    Nov 2004
    In the driver\'s seat
    108
    Kick the crap out of the tire to knock the wheels loose. They've rusted to the drums.
  5. Remove Advertisements
  6. #4
    No Cause For Alarm MichaelXi's Avatar
    Sep 2001
    Venus Via Knoxville, TN
    17,312
    Exactly.
    Kick the BeJeeezus out out the edge of the tire.
    After it comes off, place a TINY dab of anti-sieze compound on each of the 4 rust spots, and wipe off any excess. Put it on the threads as well.
    If you rotate your tires regularly, you'll never have the problem again.
  7. #5
    Oct 2000
    Pennsylvania
    6,298
    I was kicking the living hell out of mine and it still wouldn't come off. But I imagine it was due to the fact that I was driving through flood waters and that sort of caused some excessive rusting.
  8. #6
    Jun 2003
    2,838
    Think of something that make you angry and kick the crap out of the top of the tire
  9. #7
    Aug 2004
    SW; CT
    104
    Haha I'll probably be thinking about the friggin wheel itself. Thanks all, good thing I play soccer, huh. I'm in the midst of doing the SVT suspension swap, so yah, this should be in suspension/wheel and tire. I just removed the anti-roll bar while I was waiting on you highly technical advice. haha Wish me luck.
  10. #8
    TEAM Member SpeedOften's Avatar
    Jan 2004
    NH, Maine and VA
    733
    I had this problem on my wifes car so I used some PB blaster... worked like a charm..
  11. #9
    Krunktronik Tuner Goblin Honda Hunter's Avatar
    Nov 2001
    Lake Worth, FL
    3,346
    On some Foci, Ford put a 5th lug nut on the back side of the rim. It's right next to the strut bolt on the knuckle.
    It's kind of tricky to find, but you should be able to see it if you look right behind the brake drum.
    Ford did this just as an extra safety meassure to make sure that the wheels don't fall off during high speeds.
  12. #10
    Sep 2001
    17,312
    Good one...
    (For the naive, there are no knuckles or struts on the rear of a Focus, much less a 5th lug nut... )
  13. #11
    Almost choked on a Girl Scout ...cookie bigdaddyG8's Avatar
    Mar 2002
    Fresno, CA
    16,227
    jackass!
  14. #12
    Nov 2001
    Lake Worth, FL
    3,346
    Thought you guys would like that....
  15. #13
    Jun 2001
    Kent Island, MD.
    157
    If you look around the hub where it is rusted there are little notches that I just put a flathead screwdriver in there and gave it a pound or two and it popped them right off.
  16. #14
    Mr Know-It-All Peloton25's Avatar
    Sep 2000
    California, USA
    11,241
    If anyone tries Jared's method, I must recommend that you leave at least two of the lug nuts on the studs, but lose enough to allow free movement of the wheel. That way there is no chance for the wheel to actually come off in the process and do some collateral damage.
    >8^)
    ER
  17. #15
    [FJ] Specialist BowDown's Avatar
    Nov 2001
    NY State SUCKS!
    7,351
    KICK IT HARD!
