car shakes when accelerating past 60mph
FSWerks
Results 1 to 13 of 13
    Senior TEAM Member elderfeces's Avatar
    Nov 2002
    Gilbert, AZ
    2,637
    Default car shakes when accelerating past 60mph
    mkay this is really annoying me because i can't find the possible cause.
    when i accelerate over 60 mph, my car shakes. initially i thought that the new tires i just purchased were not balanced properly, so i took it back and had them checked. they were re-balanced with new weights, and the tech even showed me that they balanced at zero on the machine.
    then i thought maybe one of the VF poly mounts had broken. i checked them all, but they are all still intact and in very good shape. i have all 3 mounts BTW, and they make for an awesome, solid ride.
    i am stumped here, and it's really bumming me out... the SVT shouldn't shudder and shake when i stomp on the accelerator. and it's only when i am accelerating. when the car is cruising, say at 65 or 75, or whatever speed... it is smooth. only when i stomp on the accelerator does it shudder, and this only happens around the 60 mph mark or above.
    any ideas anyone?
  3. #2
    Jun 2002
    Janesville, WI
    1,602
    Default Re: car shakes when accelerating past 60mph
    Bearings?
  4. #3
    Nov 2004
    South Florida
    146
    does it shake in the wheel? like a steering wheel shimmy or is it felt in the seat?
    how many miles on the car?
  5. Remove Advertisements
  6. #4
    Mar 2004
    Southeast
    3,066
    Ditto, any recent mods? Have you performed any services latley? (i.e. oil change, fuel filter)
    If it shakes the wheel have you tried rotating your tires?
  7. #5
    Oct 2000
    In ur srvrz patchin ur krnlz
    6,880
    Tie rod ends, inner tie rod ball joints, control arm ball joints. Any of them could cause this kind of behaviour. It could also be something completely different, but that's where I'd start.
  8. #6
    Nov 2004
    South Florida
    146
    lets isolate where its coming from first. just because the balance was at 0, doesnt mean the road force variation was low enough not to cause a vibration.
  9. #7
    Illage Vidiot Mr. Zetec's Avatar
    Nov 2002
    Peaking through your sister’s window…
    2,601
    might just want to check if wheels are balanced
  10. #8
    Nov 2002
    Gilbert, AZ
    2,637
    i have a feeling it may be isolated in the driver's side axle... the cv boot was damaged awhile ago and i have neglected getting it repaired for 2 reasons... too lazy or too busy. i'll see if that narrows it down.
  11. #9
    Jul 2002
    New Braunfels, TX
    10,540
    blown struts. everytime. been there done that, have the T-shirt.
  12. #10
    Nov 2004
    South Florida
    146
    OMFG... yeah, i would have said that, had you mentioned it earlier...
    blown struts can cause it too, but thats usually accompanied by other symptoms.
    is it the inner CV boot? or outer?
  13. #11
    Newbie
    Feb 2010
    1
    Ford Focus Shakes when I accelerate. (5 dr hatch 2005 CLS, Australia)
    Four New Tyres ( Good Year Ducaro GA 195/65R15 ) = Now my car shakes on acceleration from about 70km’s up. Then as soon as I take my foot off the accelerator the shaking stops completely. When I am cruising at about 110Km’s it is fine again.
    I have had the car checked and checked again with no result
    1st Time = Original Purchase place (Wheels Balanced and aligned) NO CHANGE
    2nd Time = Original Purchase place (Wheels Balanced and aligned) NO CHANGE
    3rd Time = Independent Tyre Service Centre (Did not balance took for test drive and insisted it was a mechanical problem)
    4th Time = Ford Service Centre = (Wheels Balanced and aligned = Complete front end mechanical check) no result and insisted it was a tyre problem. NO CHANGE
    5th Time = Original Purchase place + Tyre Company Rep (Wheels Balanced and aligned tested with no change, then four new tyres (the same ones – not happy about that decision) were put on the car and tested with NO CHANGE) My original tyres were then put back on.
    6th Time = Independent Mechanics Service Centre = (Wheels Balanced and aligned + Front end checked with no result). NO CHANGE
    7th Time = Independent Tyre Service Centre #2 = (Wheels Balanced and aligned on brand new state of the art machine) slightly better but overall - NO CHANGE.
    PLEASE: If you have any ideas on how to help me I would very much appreciate your help.
  14. #12
    Senior TEAM Member Lancer211's Avatar
    Mar 2009
    Tucson, AZ
    3,294
    You don't have any warped hubs, do you?
    04 ATX Zetec sedan, FSW Cool-Flo, e2kIM, ported TB, header, TruBendz exhaust, SVT suspension, Steeda RSB, SVT FSB, FSW tune
    32" HDTV posted in Garage Sale!
    CarDomain Page
  15. #13
    Newbie
    Mar 2010
    Reading, Pa near Philadelphia
    1
    Since I had the same problem as Scoatsy, I thought I'd share my solution. It was the inner CV joint (passenger side) on my 2002 zx5 with 68,000 miles. The boot was damaged for quite some time as I found dried and dusty grease coating the engine parts around the boot. After sliding the boot back from the tri-pod bearing joint, I saw that the grease was almost completely gone and when I packed it an re-clamped the boot, the problem disappeared immediately. I followed up and replaced the entire half-shaft then found a deeply worn groove in one of the 3 cup lobes. Have you solved your shakes yet?
