Coolant leaks - cheap fix info! - Page 6
Rock Auto
Page 6 of 13 FirstFirst ... 3456789 ... LastLast
Results 76 to 90 of 181
  1. #76
    Jun 2004
    Aurora, CO
    89
    Thumbs up Re: Coolant leaks - cheap fix info!
    SOB. Wouldn't you know it. My first problem and now the ball is going to roll i bet. I changed my pads, rotors and put on SS lines last weekend and no leak. I move my car today to get more room in the garage and notice the leak. I almost got pissed at myself for not tightening my brake lines till i found out what it was. I ordered the 203 ring and will put it on the lift to change next weekend. If anyone needs a few send me your address and i will mail them to you. I am not going to worry about the .50 cents for shipping just willing to help others being it is cheap and sounds liek the pain to install will be more costly.
    03 SVT Comp Orange Euro Package #3165 of 3985 DOB June 20, 2003
  3. #77
    Jun 2004
    Aurora, CO
    89
    Default Re: Coolant leaks - cheap fix info!
    One more thing. Brian (HTPerformance) mentioned putting in the 180 thermostat. Is there an issue with the stocker? Does it improve something other than lowering temps?
  4. #78
    Senior TEAM Member supersonicsvt's Avatar
    Feb 2005
    Atlanta GA
    1,229
    All it will do is lower the normal operating temperature under normal conditions. It doesn't mean your system will now remove move heat - that takes a bigger radiator. It will just open to allow flow to the radiator sooner.
    DD - '02 Sonic Blue SVT #504 Steeda springs, Koni Sports, 25mm adj RSB
    Track Rat IS BACK!!! - '02 Black SVT H&R race springs, Koni Sports, 25mm RSB, Carbotech brakes, NT01s, 67mm TB, oil & PS coolers, Autopower roll bar, Schroth harnesses, Sparco seats (and "custom" rear bodywork)
  5. Remove Advertisements
  6. #79
    Premier Sponsor HTPerformance's Avatar
    Apr 2005
    Bridgewater, MA
    1,194
    I made up a webpage for the info regarding getting the replacements. Quite a few people have asked for Priority Service and that is now available.
    http://htperformance.net/thermorings.html
    email me @ brian@htperformance.net if you have any questions!
    Brian Hult
    Founder
    HTPerformance - Superior Components for the True Enthusiast.
    30 First Street, Unit #3
    Bridgewater, MA 02324
    Ph: +1.508.659.4466
    E: brian@htperformance.net
    Follow me on Twitter: http://twitter.com/HTPerformance
    Follow us on Facebook: http://www.facebook.com/pages/HTPerf...ET/32467520987
  7. #80
    Feb 2006
    102
    Sorry about bumping this up but I just fixed my leak by replacing the o-ring but I managed to lose the clip because I am retarded. Where can I find replacement clips? I already went to my local hardware store and they had nothing similar to the clip. Thanks!
  8. #81
    Jan 2007
    St. Michael, MN
    66
    ford has the clips and they are $2.30 each retail part # as follows:
    W703355-S303
    2002 black FSVT
    NO frills
    and dirt cheap
  9. #82
    Dec 2002
    Maine
    389
    Took my SVTF to get some rear bushings replaced...they not only replaced the rear lower, front, swaybar but noticed the coolant leak and replaced the thermostat and everything under my extended warranty...this work and replacing my moonroof a few months back pretty much paid for the extended warranty..
    04 Volvo S60 R
    06 Honda Civic Si - Gone
    02 SVT Focus, CD Silver No. 2032
    (Totalled)
  10. #83
    TEAM Member PressBox's Avatar
    Nov 2004
    Charlotte, NC
    870
    Argh, just noticed this leak this past weekend, does anybody mind sending me the #203 and #109 O-Rings? I'd be very appreciative, PM me if so and i'll get info to you!!!!
    Thanks guys,
    Clif
    SLVRbulletSVT03
    Formerly SLVRBulletSVT03...
  11. #84
    Senior TEAM Member SVTF4243's Avatar
    Jan 2003
    Pasadena CA
    1,240
    Red face Re: Coolant leaks - cheap fix info!
    Quote Originally Posted by SLVRbulletSVT03
    Thanks guys,
    Clif
    SLVRbulletSVT03
    It's right here:
    Quote Originally Posted by HTPerformance
    Silver ST3 MR::: 02 11 2013:::::::::::::::::::::Silver SVT::: 11 10 2002 :::SVTF4243.COM
    MODS ::::::: DONE ::::::: PLANNED
    GO :: Cobb RRM | Accelerator petal mod | JBR OCC | STS | Rear Swaybar |
    Springs | Tune
    SHOW ::
    Hide A Plate | Calipers Painted | Gunmetal Wheels | Back up Cam | Window Tint | Lights tint |
  12. #85
    Dec 2002
    Bay Area, CA
    1,227
    In replacing this o-ring, and putting it in a new thermostat housing, does the housing come with a gasket?
  13. #86
    Mar 2003
    Pataskala Ohio
    885
    About the thermostate.
    Hotter is better! More power. Modern engines are designed to run hotter for clean exhaust and more power. I recommend leaving stock.
    Better for burning off water from the oil, etc. Many benefits from a hotter running engine, of course up to the design limits.
    LEM
    2007,2008, 2009 NASA Spec Focus racer w/ LCR racing
    2002 SVT, Sonic Blue, NO options,
    vehicle 896 of 4788
    Held at the factory Apr-June 02
  14. #87
    Feb 2003
    Atlanta, GA
    2,181
    Any directions lying around for the non-warrantied?!?
    CCC
    "The Raven"
    150.5hp / 131.8tq
    2002 Pitch Black SVT (#2610 of 4788)
  15. #88
    Dec 2002
    Bay Area, CA
    1,227
    I ordered a baggie of these today. If anyone needs one/wants one or two "just in case" , PM me your name & addy so I can pop it in the mail.
  16. #89
    Senior TEAM Member oskarSVTee's Avatar
    Feb 2005
    Somewhere in the Desert
    2,571
    Quote Originally Posted by LamarWH
    PM sent and a big thanks.
    2004 SVT Focus - 5 Door Sonic Blue with EAP - 1 of 48
    Build date: 1/28/04 - Drove it home: 2/14/04 - Sold: 3/29/16
    Steeda STS, FS Front Strut Bar, VF Rear Motor Mount,
    LED Tails with the MIKE Mod, HID Foglight Upgrade, FS SCT XCalibrator2,
    FC 65mm TB, CFM Hi-Flo Cat, Esslinger UDP and FRPP Multimatic Suspension
  17. #90
    Newbie
    Jun 2007
    3
    Hey,
    I've recently noticed a coolant leak into my spark plugs. My car hasn't misfired (yet), but I was wondering if you ever figured out why the leak was occuring. I have already replace the T-stat housing. If you did or do, just e-mail me or reply. If not and I find out soon, I'll send you word.
    Thanks!
