Fog lamp "on with high beams" rewire - how to
Perfect Circle Autosport
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Jun 2005
    6
    Default Fog lamp \"on with high beams\" rewire - how to
    I was able to rewire my fog lamps on my F150 to stay on with the high beams with instructions from an F150 forum. Does anyone know how to make this same mod for a 2005 ZX5?
    It is a very noticeable improvement to your ditch and forward visibility on dark country roads...
    Thanks in advance!
    Brent
  3. #2
    Educating Mazda Owners One Thread at a Time Nliiitend1's Avatar
    Sep 2001
    Chicago
    4,721
    Default Re: Fog lamp \"on with high beams\" rewire - how to
    do a search for "Foglight mod" or check out www.focushacks.com. If you do the "foglight mod" then your fogs will also stay on when you turn on your highbeams
  4. #3
    Jun 2005
    6
    Thanks! I saw that mod on focushacks, but misread the subject. I thought that made the mod to only have the fogs on with the park lights. Up in Canada we have daytime running lights, so the hack didn't make much sense to me at first.
    Thanks for the help!
  5. Remove Advertisements
  6. #4
    Sep 2000
    Canada, Eh?
    1,543
    did u remove the DRL as well? that would also give u an added functionality of the fog-light mod.
  7. #5
    Aug 2003
    Carpentersville, IL
    763
    Mine dont.
  8. #6
    Sep 2001
    Chicago
    4,721
    Mine dont.
    hmm, that's weird. I've had two '01 ZX3's and have jumped the terminals on both of them the same way, and my fogs stay on when I turn my highbeams on in both my current and former car.
  9. #7
    Aug 2003
    Carpentersville, IL
    763
    Maybe its my car. If I click the brights on the fogs go off but if I hold the brights on like for flashing or somthing, the fogs stay lit.
    meh.
  10. #8
    [FJ] Specialist Silfox's Avatar
    Feb 2003
    Austin, TX 78729
    6,779
    meh.
    Well, that is how it acts from the factory. You are saying they still come on after you have done the foglight mod?
  11. #9
    Aug 2003
    Carpentersville, IL
    763
    I think Bleed4speed wants his fogs to work with the brights clicked on Ive done the foglight mod and it does'nt change that. It just allows you to run the fogs with teh parking lights.***edit and the headlights. no brights 4 me
  12. #10
    Sep 2001
    Chicago
    4,721
    that is definitely an anomaly.
  13. #11
    Jun 2005
    6
    To clarify: I want to have the fog lights on with the high beams (maximum lighting).
    I went to do the fix last night, and in the 2005 ZX5 there is no R13 relay installed! No relay, no wiring to the relay socket, nothing.
    Does anyone know how to do this mod on an 05 Focus?
  14. #12
    Feb 2003
    Austin, TX 78729
    6,779
    Sir, I've done this mod on an '05. Everything works fine. Foglights come on with the parking lights and will stay on with the highbeams. Even if there isnt a relay in place, try doign the mod as if you just pulled the relay out. I cant remember if the '05 I did had a relay or not.
  15. #13
    Jun 2005
    6
    There's no wires onto the bottom of the socket base for R13 (assuming I've got the right relay identified...) which I discovered after I stuck the jumper in & found no change to the lighting.
    I'm in Canada - is there a chance that the Canadian cars have different wiring to accommodate the daytime running lights?
    Thanks for the replies so far, BTW!
  16. #14
    Feb 2003
    Austin, TX 78729
    6,779
    Well, I'm lost then. If there are no contacts, then obviously its not going to work!
    I'm out of ideas, spent.
  17. #15
    Aug 2003
    Carpentersville, IL
    763
    did you have a good contact?
    http://www.jwardell.com/focus/foglight.html
