Alternator Removal
FJ Gear Store
Results 1 to 13 of 13
    Oct 2005
    42
    Unhappy Alternator Removal
    I have to replace my alternator in my 2000 Focus se w/Zetec (automatic).
    Well, I folowed Haynes Repair Manual and I'm at the point of removing it, but it just doesn't fit nomatter what way i turn that darn alternator. It just won't come up.
    there's always something in the way.
    Also looked at focushacks.com, and it looks so easy, however there is some kind of metal part of the engine in the way that I can't remove.
    Can anyone help plz. ?
  3. #2
    Feb 2002
    Burnsville, MN
    859
    Default Re: Alternator Removal
    Automatic Zetec Foci have the engine located over "1 more towards the firewall. You have to fuss with it to get the alternator up and out; I have been there.
    2004 ZX3 2.3L Pitch Black, Manual - to be installed: Cosworth IM, CFM 67mm TB, AEM intake ,OBX header, Borla exhaust, CFM UPD, CFM BSD, Crane stage-1s, 4.06 FD, Torsen T2, Exedy OEM clutch
    2001 ZX3 Infra Red, Automatic - returned to stock
  4. #3
    Aug 2004
    Youngstown,OH
    511
    when removing the alternator make sure the pully is facing up. You'll have to remove everything in that corner, evap purge canister, coolant reservoir, p.s. fluid reservoir, engine ground to strut tower, etc...
    After you remove all that its just a matter of finessing it out of the hole you just created. What does this metal part on the engine look like? If you're talking about the lift lug by the engine ground above the alt. you don't need to remove that.
    2000 Pitch Black ZX3 Vortech Aftercooled
    2006 Pitch Black ZX4 ST SAP Focus Sport Stage 2 Turbo
  5. Remove Advertisements
  6. #4
    Oct 2005
    42
    it's part of the fuel rail. is there a way to move the engine an inch or two towards the front of the car by unbolting the passanger engine mounts?
  7. #5
    Oct 2000
    In ur srvrz patchin ur krnlz
    6,880
    I got under my car, removed the lower trainsmission roll-restrictor mount, rocked the motor, and pulled it out between the steering rack and engine.
    Vehicles: ['12 SE Hatch] ['00 ZX3] ['03 Explorer] [Trek 1200]
    [FocusHacks] : Ford Focus Tech & Maintenance Tips
    Elsewhere: [Blog] - [ + ] - [ t ]
    [HiR Information Report (rss)] : Get your fill of Geek Humor, Security, and Unix
  8. #6
    Oct 2005
    42
    What does the the lower trainsmission roll-restrictor mount look like?
  9. #7
    Senior TEAM Member Broke_Two_Foci's Avatar
    Jan 2005
    At Work
    4,564
    it looks like a dog bone. one large end aproxamatly 2.5" in diamater. and a small end aprox 1" dia. it connectes between the trans and the subframe underneath the car.
    the way axon pulled his is the same way I did mine twice now.
    you may want to check the wiring from your alternator to the battery for burned spots. that is what destroyed my second alternator.
    2004 Mercury Grand Marquis (Dr. Jekyll), 2004 Honda CBR1000RR (Mr. Hyde), 2003 Ford Expedition (Monster)
    55MPH, Ha Ha Ha, Faster Than A Speeding Ticket... RIP Korey
  10. #8
    Dec 2002
    wherever the wind blows
    407
    Quote Originally Posted by rollo78
    yes there is, just take off the 3 bolts holding down the passenger side engine mount. then put a jack under teh oil pan with a small 2by4. now, you are able to lift up the engine enough to get out teh alternator(I should know because I have done it twice).
    a Ford man workin for the devil (Chevy)!
  11. #9
    Oct 2000
    6,880
    for what it's worth, if I had an engine hoist I would have seriously lifted the engine out to do it.
  12. #10
    Oct 2005
    42
    What is the metal part right under the lift lug?
    can it be removed?
  13. #11
    Oct 2000
    6,880
    That's the fuel rail, if you're seeing what I think you're seeing. I would not mess with it.
  14. #12
    [FJ] Specialist secondechomatt's Avatar
    Apr 2005
    Trenton, MI.
    5,291
    Takes a lot of finese, guiding it (prying, kicking, hitting with a hammer, etc.) to get it out of there. For some reason, putting the new one in was a piece of cake!
    1998 Expedition "Jack" Bauer edition, 2010 focus SE
  15. #13
    Sep 2005
    Southern Ohio
    1,935
    Just did mine yesterday(01 SE Zetec w/ AT)
    The ONLY way I found to do it:
    *Remove all the goodies as mentioned in Haynes/Chilton:
    Evap Canister
    Coolant overflow
    P/S Reservoir
    Engine Harness plug
    *Remove belt from alternator pulley
    *Unbolt alternator
    *Unbolt lower engine mount(tranny mount)
    *Unbolt passenger side engine mount @ body attachment(3 15mm bolts, I think)
    *slide engine forward
    *pull engine with all your might while another(or yourself if brave) person finesses alternator out.
    If it makes you feel better, it goes in MUCH easier.
    FYI: i just had mine rebuilt for like $70. They replaced everything inside, other than the rotor.
    Greg
    2003 CD Silver SVT Sunroof and Machs#1229 of 3985 Date of Birth April 21, 2003
    Borla Cat-Back/SVTF tip,Custom ORP,Steeda Short Throw,FRPP 9mm Plug Wires,Upgraded "Big 3",HIA Short Ram,Xcal2 tuned by FocusSport,SRF Stage 2 TB,EAP Wheels,Audiophile sub, Euro Grill,Clear Bumper Lenses...Blown Head Gasket :(
    2004 Infra Red ZTS--2.3L/5spd - killed by a giant deer.
    2014 Tuxedo Black Fiesta ST. Stock, for now.
