Rear Seat removal question
Tasca Auto Group
Results 1 to 12 of 12
    Oct 2002
    San Jose, CA
    1,383
    Default Rear Seat removal question
    I am thinking of taking my rear seats out for an event this weekend to save a few pounds on the car and I was wondering how hard it is to do so and how much work would be needed to put them back in after the event is complete.
    2002 Focus SVT / Mildly Solo II DSP Prepped - Sold to Smike
    1999 BMW E36 M3 - Obnoxious
    2008 VW GTI - The girlfriend's car
    Dave
    Applications Development Engineer at KLA-Tencor
    Pattern Wafer Inspection - Dark Field
  3. #2
    9 and 3 Damnit! 9 AND 3!!!!!!!
    Aug 2004
    Apex hunting
    9,347
    Default Re: Rear Seat removal question
    It is a lot hatder the first time. But it is still not too bad. A lot of the bolts are pretty tight though so it takes some effort to get em out. They will go back in in like 30 minutes or so maybe a little more if you remove all the brackets too
    "America is all about speed. Hot, nasty, bad ass speed."
    Quote Originally Posted by OmniFocus
    I view every broken OEM part as an opportunity to make the car more awesome. For example... my stock air filter was dirty, so I installed a supercharger.... and my axle seal was bad, so I installed a diff, clutch, and gears
  4. #3
    Resident Wheel-Whore
    Oct 2004
    Boost Crew
    10,594
    There is the screws in the front, those hold down the butt piece. The backrest just fold down, and there are 2 screws on eash hinge. Its pretty easy.
    2016 Subaru WRX STi
    1980 Mk1 Volkswagen Rabbit
    ~~BOOST CREW, Bottled Fresh since 2006 ~~ Vacuum Crew, Stirring things up since 2008~~ C-LIST~~
  5. Remove Advertisements
  6. #4
    Stoned Scorpion says, "GET OVER H.....OOhhh! Brownies!" Spatakula's Avatar
    Jul 2005
    Rälëigh, NC
    11,973
    the screws holding the back piece in place are kinda tough to get to. takes some persuasion but it is pretty easy.
    (ノಠ益ಠ)ノ Y U NO LIKE SOLOAUTOMAG?!?!?!
  7. #5
    Senior TEAM Member REDFOCZ's Avatar
    May 2004
    Orlando, FL
    1,183
    Like every said the frist time will be the hardest. Took me about 40 mins to take tem out and about 30 to put them back in.
    2012 focus SE hatch with sport package
    Mods: Steeda Intake, STS Kit, Rear sway bar, Lowering springs, MS3 RMM, Magnaflow catback, & SCT Tuned
    Dyno numbers: 177 HP and 163 TQ
  8. #6
    Don't Call Me Gaga!
    Jul 2001
    30,266
    Two different size heads, BTW... T40 and T45 if memory serves. I just removed my last night.
    I have too many cars.
  9. #7
    [FJ] Specialist secondechomatt's Avatar
    Apr 2005
    Trenton, MI.
    5,291
    PB blaster is your friend here! Once you know what you are doing, should take about 15 mins from beginning to end. I did a whole interior swap in about an hour. Including the panels.
    1998 Expedition "Jack" Bauer edition, 2010 focus SE
  10. #8
    Senior TEAM Member ButteryBunz's Avatar
    Apr 2010
    Minneapolis MN
    1,133
    I just took mine out, any idea how much the seats weigh? My scale is broken.
    2014 Fiesta ST
  11. #9
    Apr 2010
    Minneapolis MN
    1,133
    nvm, they are 43lbs, sorry.
    2014 Fiesta ST
  12. #10
    Mar 2009
    Dyer Indiana
    681
    sorry to kinda highjack your thread but they really weigh 43 pounds? i would expect 25 at most
    Past:
    00 sedan
    02 SVTF #1068
    Current:
    02 SVTF #4743
    04 Kawasaki Ninja
  13. #11
    Newbie
    Feb 2011
    2
    The seats and all removed hardware weighs 53 lb. I weighed them.
  14. #12
    Newbie
    Feb 2011
    2
    To remove the bolts holding the seat brackets to the floor, first remove bolts from seat backs, lower bottom both sides of both seats, you can feel the bolts through the fabric covering them, then you have no problem accessing the bolts on the floor.
