Manual Transmission - Fluid change?
Rock Auto
Page 1 of 4 1234 LastLast
Results 1 to 15 of 49
    Apr 2002
    (Nathan) Tacoma, Washington
    145
    Default Manual Transmission - Fluid change?
    How often are you supposed to get your gear oil changed out for your manual transmission? I was talking to a mechanic today who said in a manual ford you never need it changed unless you do tranny work, and one I talked to a few weeks ago said get it changed at 30k. So I'm at about 31k now, and... what do I do?
  3. #2
    Senior TEAM Member Broke_Two_Foci's Avatar
    Jan 2005
    At Work
    4,564
    Default Re: Manual Transmission - Fluid change?
    I have always heard about 30k. I am doing mine this weekend. of course I do not have the best track record with ford transmissions. so I am hoping every little bit helps. by the by if you get the fluid from ford it will probably be $20 a quart. luckly you only need 2.
    2004 Mercury Grand Marquis (Dr. Jekyll), 2004 Honda CBR1000RR (Mr. Hyde), 2003 Ford Expedition (Monster)
    55MPH, Ha Ha Ha, Faster Than A Speeding Ticket... RIP Korey
  4. #3
    Apr 2002
    145
    So it's a good idea to change at 30k?
  5. Remove Advertisements
  6. #4
    May 2004
    Fremont/Newark, Ca
    2,754
    30k is a great time to change it.
    The sooner, the better.
    Motorcraft XT-M5-QS is good good stuff....
  7. #5
    Apr 2002
    145
    I've heard changing it in a manual is a pain in the ass... would it be better to take it in? And, to who? Dealers are usually way expensive... who else does it?
  8. #6
    Apr 2002
    145
    I pulled up suggested maint. on the ford website, and oddly enough, through 150k it never suggests to change the Tranny fluid.
  9. #7
    May 2004
    Fremont/Newark, Ca
    2,754
    Yea, trust me, you'd want to change the tranny fluid if you drive your car hard.
    Walter Marcy suggests changing the tranny fluid in the mtx75 at 30,000 miles.
    I asked him If i was due at 50K miles, and he told me I was 20K overdue... so yea...
    To put this off for 150,000 miles is just retarded In my opinion.
    Changing the fluid isn't any harder than changing the oil for the car.
    I used a valve attached to a hose that screws onto any ATF/tranny fluid bottle.
    Stick the end of the tube in the oil fill plug located on the front of the tranny, halfway up. flip the bottle upside-down, then release the valve. Repeat for the 2nd bottle.
    The drain plug is at the bottom, obviously.
    You can do it yourself, the only thing that sucks is transporting the fluid in your car for disposal. Pouring it down the drain or gutter isn't very cool...
  10. #8
    Oct 2003
    San Diego
    1,276
    The drain and fill plugs have a specific torque setting, if you do this, I suggest you torque them back on correctly. IIRC, it was 33ft-lbs...but that sounds high for some reason. Check before using those numbers
    "Guns don't kill people, physics does!"
    "take a can of WD-40 and spray a SMALL amount ONLY A SMALL amount on the pads and bam the noise is gone and the breaks work just like new..."
  11. #9
    Aug 2005
    Litchfield MN 55355
    1,197
    I made a bong to fill my trans with...
    *TOTALED*2003 Pitch Black Slocus-First and, so far, the only focus in MN with the SVT DSI manifold on a non-svt car.
    FS 4-1 header, Magnaflow catback w/ resonator, Crane 0012 cams, SVT DSI, custom air intake, VF solid poly mounts, the rest, doesn't add to the 'go' factor, therefore, not important.
  12. #10
    TEAM Member microtonal's Avatar
    Sep 2003
    Seattle, WA
    883
    Quote Originally Posted by SpeedoZX3
    Changing the tranny fluid is as easy as changing the oil.
    I believe an 8mm allen wrench will work for the fill and drain plugs.
    1. Make sure you can remove the refill bolt first.
    Don't remove the drain bolt until you can remove the fill plug or you may drain the fluid and then be stuck high & dry if you can't remove the fill plug.
    2. After the fill plug has been removed, remove the drain plug.
    3. Let it drain for 15-20 minutes to the fluid drip out as much as possible.
    4. Install drain plug and use a long(15in or longer) bendable funnel to get to the fill plug and fill fluid.
    *It takes about a little over 2 quarts to fill.
    Also, may car came with Motorcraft XT-M5-QS and it always felt notchy when shifting from day one.
    I changed the fluid to Amsoil Synthetic ATF and it's much smoother.
    Here's some pics that might be helfpul.
    Tranny fluid plug/fill hole
    Pic of funnel inserted in the fill plug from engine bay
    Drain plug
    Quote Originally Posted by Steel Panther
    Because eatin' ain't cheatin'
  13. #11
    Ho, ho, ho... Green Giant whiteboyslo's Avatar
    Apr 2003
    San Diego (soon, very soon)
    4,287
    cakewalk. hell, the hardest part for me was finding the damn drain plug!!!
    also, i highly recommend Royal Purple Synchromesh if you can find it. i've used it in a few vehicles with very good results!!
    Mike
    How am I supposed to take your post seriously when you think an apostrophe is needed when pluralizing?
  14. #12
    Apr 2002
    145
    You guys rock. Thanks! Does it need to be on a lift or will ramps do the trick?
  15. #13
    Oct 2003
    San Diego
    1,276
    Looking at the position of the drain plug, it being on ramps should not impact it much. However, measure the amount of fluid you get out...if it is way off the capacity of 2.1qts, level the car by jacking up the rear.
    If you use a jack instead of ramps, you could just low the car back to the ground after you open the drain plug.
    (you won't get all the old fluid out, but you should get most)
  16. #14
    Oct 2000
    La Mesa, CA
    686
    Pzev, how is MTL-P?
  17. #15
    Oct 2003
    San Diego
    1,276
    I have not been able to order it, as Specialty Formulations is not taking any orders till the 5th of July. I guess they are all on vacation
    And I am going with MTL-R, as it more closely matches the viscosity of the Ford Honey. (Although, MTL-P is really tempting because of all the good reports with it)
