Dog bone motor mount?
Tire Rack
Results 1 to 15 of 15
    Dec 2005
    Osceola, WI
    598
    Default Dog bone motor mount?
    Whats the easiest way to install the new polly inserts in the dog bone trans mount? And how much vibration should I expect with my BS delete?
    04' F350 6.0 Powerstroke!
    1995 OLDS Delta 88 & 1991 Mustang LX 5.0l - 5spd autox project!
    Greatly missed: 05' ST: 136HP/142TQ
    http://www.cardomain.com/ride/2245176
  3. #2
    DoubleStuf™
    Jan 2005
    Parkville, MD
    3,716
    Default Re: Dog bone motor mount?
    Installing the inserts is easy. You can press in the new ones by hand or by stepping on them. The trick is getting out the OE bushings. It's not horrible, but the big one is a little tough. The small one can be hammered out. The big one requires cutting- and that rubber is very hard to cut.
    On a stock tune you're going to have quite a bit more vibration at idle. Almost like one cylinder is missfiring. A new tune with an idle raised to about 950rpm will eliminate the vibration pretty much completely.
    It's a VERY worth while mod though. It was the first thing I did & still one of the best.
    Now being tuned by the world class, fastest of the fast, baddest of the bad-ass worker of hokus-pokus on the focus! Give it up for Mr. Randy Robles of FSWerks!!
    Torsen, 4.06,
    Fidanza FW, Luk ProGold clutch, Cosworth IM, Stg 2 Crane cams, Eagle ConRods, 12.5:1cr 88mm Supertech pistons, CFM Adj. cam gears, Cosworth CAI, Draxas & Trubendz exhaust, SVT Brakes, ST200 Rims, Koni Sports, Apex springs, poly FLCA & dog-bone bushings, Progress 22mm RSB, TriAx/F STS, XCal2- *Now with more ProRacer!*
  4. #3
    Mar 2006
    Louisville, KY
    3,590
    both are hammerd out. what I did was stick a flat head screwdriver down the side of the big one to loose it up then hammer it out.
    Press in the new and reinstall..
    The only standing control arms is your goal for the first time.
    If weapons killing people, scoops, make Mihajl′ Moor and fat Rosie O'donnčl′!
  5. Remove Advertisements
  6. #4
    TEAM Member ZX5GO's Avatar
    Jun 2003
    Missouri
    220
    I took my to a local O'Reily and they charged me $5 to press them out.
  7. #5
    Apr 2005
    Roberts, WI
    323
    How are the vibs on the 2.0? Is there any benefit to doing just one, if so which one?
    MAT
    Roberts, WI
    05 ZX3 SES Infra-red (It's hot!)
    Major Mods: Marcy CAI, Borla cat-back exhaust, Crane Stg 1 cams, F2 Header, FS tuning, SVT suspension, 17" FRPP rally wheels. (I'm just getting warmed up!)
  8. #6
    Jun 2003
    Missouri
    220
    I had a VF rear mount in my previous Focus and the vibs were almost too much to live with. I have heard that this varies somewhat from car to car. I haven't installed my mount with added bushings yet but I was hoping that it would be a little less harsh than the VF mount.
  9. #7
    Dec 2005
    Osceola, WI
    598
    Quote Originally Posted by MAT
    I think the trans mount is the main mount to get replaced by the average focus nut. Its also the easiest of the three to do I think. My goal is for this to eliminate my engine from banging against the fire wall under hard shifts in autox or hard driving.
    Mat I will be installing the mount friday and will post a review. Also if you would like to find out how much vibration there is in person I can meet up with you this weekend and you can check it out.
  10. #8
    Aug 2005
    Lakeland, FL
    279
    how much are these poly inserts? and where can i find them?
    2005 Sonic Blue Zx3- Focus Sport Cold Air intake, Custom exhaust,Draxas header,Focus Sport tuned Xcal2, Steeds Tri-ax short shifter,RS Wheel, Eibach Sportline springs and SVT shocks and struts, painted headlights, grille, and interior, Focus Sport front strut bar, SVT Lip,. Kenwood Headunit,Pioneer 6x8s...you know....the usual.
  11. #9
    Dec 2005
    Osceola, WI
    598
    Quote Originally Posted by afn05focus
    I got mine from WWW.NEWEDGEPERFORMANCE.COM. The inserts are cheap but you can also buy a complete mount for $100 or so. I also bought a used stock dog bone mount from someone for $20. So that I can revert back to stock when ever I want.
    http://www.newedgeperformance.com/in...ROD&ProdID=182
  12. #10
    Dec 2003
    775
    Has anyone tried a solid mount?
    I was considering fabing up a solid mount and seeing how it was.
  13. #11
    Aug 2004
    Union, MO
    8,101
    I think one of the drag racers ran a solid mount for a while. It might have been Benny, or maybe 0103VENOM?
    '04 PZEV ZX3
    Well done, android. The enrichment center reminds you that Android Hell is a real place where you will be sent at the first sign of defiance.
  14. #12
    DoubleStuf™
    Jan 2005
    Parkville, MD
    3,716
    I suggested this very idea a long time ago & several times since- replacing only one of the two bushings. I don't think anyone has tried it yet but I'd be super anxious to find out how well it works. If you don't like it after all it's just another 15min to put the other bushing in. If trying this though I would replace the large bushing with the poly. The smaller bushing doesn't allow as much slop yet still will give just enough room to let the engine vibrate without transferring that vibration to the rest of the car. Or at least that's my theory.
    Torsen, 4.06,
  15. #13
    Apr 2005
    Roberts, WI
    323
    I bought the prothane poly lower engine mounts from CFM -
    http://focus.c-f-m.com/index.asp?Pag...PROD&ProdID=53
    Is this the same thing as the trans mount? If so I might give one a try.
    MAT
    Roberts, WI
  16. #14
    Dec 2005
    Osceola, WI
    598
    Yes the dog bone is the lower trans mount.
  17. #15
    Sep 2006
    angola, NY
    1,551
    where can i get inserts for the other mounts??
    2006 zx3, 2.0 PZEV. Toreador red
    Body Mods: Roush front fascia, HIDs (6k), 5% Tint, Blue turns, Silverstar fogs, painted headlights, BOSCH wipers.
    Performance Mods: MBRP exhust, F2 CAI, F2 Header, Cosworth Cams, CFM 65mm TB, FC short throw, Steeda MIL eliminator, energy dogbone inserts, SVT 5 spoke wheels w/ Hankook K106 rubber, SVT dampers and FRPP 1 1/2 drop springs, Bix RSB retrofit, Eibach anti-roll kit(22mm front/25mm rear), slotted rotors and Hawk HPS pads, XCAL2 by FocusSport.
