pcv valve 2.3?
Tasca Auto Group
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: pcv valve 2.3?
    Mar 2005
    143
    Default pcv valve 2.3?
    Can someone tell me how to get to the pcv valve on my 2.3? I poked around a bit yesterday and couldn't seem to locate it. A pic would be nice but a good explanation would do as well. I'm at 80k and I think im a bit past due.
    Thanks!
  3. #2
    Sep 2007
    Missouri
    2,201
    Default Re: pcv valve 2.3?
    Daven, most models have the PCV valve located in the crankcase ventilation oil seperator, which is mounted lower on the engine.
    The way my manuals describing this, you need to raise the vehicle, put it on jackstands, remove the splash-shield, remove the intake manifold for access to the PCV valve, disconnect the PCV hose on the valve at the seperator, Push in the two tabs, and twist the PCV valve out.
    It then says that on all models, SPI/Zetec/Duratec to test the valve, shake it vigorously. If it doesn't rattle, replace the valve.
    Hope this helps.
    "Women should come with warning labels.... Everything you do seems to be wrong, and can never be fixed."
    1980 F250 Ranger 4x4, 400M, headers, dual exhaust
    1999 Crown Victoria "P71"
  4. #3
    Senior TEAM Member sutyak's Avatar
    Dec 2005
    Fairmont, WV
    1,006
    This is for a 2006 2.0 Duratec. I can only assume yours would be in the same location.
    It's the blue thing and is behind the intake manifold.
    mark <><
    04 Mach 1. Built. Turbo. 667whp/631wtq
    '06 Focus. Built. Turbo. WMI. (sold)
    '03 Mach 1 : 12.61 @ 106.59 (sold)
  5. Remove Advertisements
  6. #4
    Mar 2005
    143
    Thanks for the help guys! I'll have another go at it later this afternoon. They sure did put it out of the way...
  7. #5
    Sep 2007
    Missouri
    2,201
    Daven, not a problem. Please let us know how it goes.
  8. #6
    Apr 2005
    San Jose, CA
    1,666
    is that replaceable?
    Garage as of 5/19/14
    2003 Focus ZX3 Turbo 2.3L
    2003 Focus ZTW
    2003 Honda Civic Hybrid
  9. #7
    May 2005
    Puyallup, WA, Do the Puyallup!
    3,589
    yes it is...
    2005 CD Silver ST-T - Too much FWHP! - SOLD!
    2007 CD Silver ST-T - Just enough FWHP! - SOLD!
    2008 Pearl White Mazda5 - Pimpin' Momma Wagon! << Now Dad's Pimpin' Kid Hauler - SOLD
  10. #8
    Sep 2007
    Atwater/Merced
    119
    Leave it to ford! Remove the intake manifold to replace a pcv
    07 ZX4 FC CAI and 2.5 catback for now
  11. #9
    Mar 2006
    Louisville, KY
    3,590
    well its not like it would fail.. Im sure the fail rate on that peice is very low.. .
    The only standing control arms is your goal for the first time.
    If weapons killing people, scoops, make Mihajl′ Moor and fat Rosie O'donnčl′!
  12. #10
    Sep 2007
    Missouri
    2,201
    Theoretically it's fail rate is low, but anything can fail. LOL
    Just like the electronic struts on Taurus SHO's, and Cadillac's were supposed to have a very low fail rate. Mom's already replaced her's on the SHO, and it's now just climbed past 100K since replacing them I think?
  13. #11
    Mar 2006
    Louisville, KY
    3,590
    your taking about somthing way differnt as a strut has way to many variables. Road condition, Driver, list goes on...
  14. #12
    Sep 2007
    Atwater/Merced
    119
    Probably it is low. But when its out of warrenty and they hand you the bill for the replacement , I bet you would really like to shake the hands of the engineers who put it there.
  15. #13
    Mar 2006
    Louisville, KY
    3,590
    suck it up and install the part...if you cant work on cars.. then don't mod them.
  16. #14
    Sep 2007
    Missouri
    2,201
    Bryst, yes, there are tons of variables on struts. I was just trying to give a different example, and apparently I chose a bad one.
    I agree with Bryst about sucking up, and doing it, or just not modding them.
    It's more enjoyable if you can work on/mod your own car. It also saves tons of money. Just be sure you feel comfortable with the task you're getting ready to perform though.
  17. #15
    Mar 2006
    Louisville, KY
    3,590
