Too Much RTV... how to remove?
Tire Rack
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
    [FJ] Addict
    Apr 2002
    19,264
    Default Too Much RTV... how to remove?
    when we rebuilt my engine last time.... it seems as though we used a little too much RTV between the oil pan and the skirt. Unbolted that bitch and it is NOT coming off. No way no how nuh uh.
    I tried to get a putty knife in there, but its not having it at all.
    So how would you recommend attacking this task? I was able to get the block and skirt seperated by unbolting the oil pickup tube.. but I'm gonna need to get that oil pan off before I get it back together.
    Recommendations?
    The queen of the missions....
  3. #2
    Senior TEAM Member ladybug04's Avatar
    May 2004
    in the the mountains, Or
    2,734
    Default Re: Too Much RTV... how to remove?
    exacto knife?
    Project pinky the crazy can corolla
    -04 focus(blown motor, waiting for donor and money)
    for sale: TC6 Factory team Buy it!!!
  4. #3
    [FJ] Addict
    Apr 2002
    19,264
    if the putty knife can't penetrate......
    I'm more looking for a solvent.
  5. Remove Advertisements
  6. #4
    [FJ] Addict brads03zx3's Avatar
    Sep 2004
    Traffic
    11,368
    Nothing's gonna get it off. RTV is chemical resistant as far as I know. As has been mentioned, a razor blade would be your best bit. A putty knife is pretty dull. Or a hammer and a flatblade, though that may require purchasing a new pan.
    Mountain Tested----'03 zetec
    ZX3 vs MNTN - 15-2 & ZX3 vs TRACK - 23/1 JCM Racing #88
    Vacuum Vulture Racing - We Make You Less Powerless
    Quote Originally Posted by norcalfocus01 View Post
    ...too short to be a dick.
  7. #5
    Mar 2007
    driftless WI
    6,005
    I'm sure the stuff is resistant to all petroleum solvents, but maybe not to stong acids. You could try battery acid (sulfuric), or go to a hardware store and get Muriatic acid (hydrochloric). One of those might do the job, the only down side is I'm not sure how well the metal will stand up to either one, especially the sulfiric. But if it loosened it up quickly enough, it could work out.
    Just make sure you have a couple of big boxes of baking soda and some water near by. Good luck.
    2002 Gold SE (Ghia) Focus, heavily modified... killed by a terrible driver
    2004 Silver SVTF w/EAP, #800... sold, to become a track star
  8. #6
    [FJ] Addict
    Apr 2002
    19,264
    Quote Originally Posted by brads03zx3
    I've tried a utility knife as well. Several of them They aren't penetrating.
  9. #7
    Senior TEAM Member v8FociDreams's Avatar
    Jan 2007
    Carlsbad, CA
    1,668
    hammer and chisel
    Quote Originally Posted by LamarWH
    Is Dateline NBC even trying anymore? Must have been the new one.... "To Catch A Jackass"
  10. #8
    [FJ] Addict
    Apr 2002
    19,264
    Quote Originally Posted by v8FociDreams
    hammer and chisel
    If I didn't care about the parts to use them again, then I'd just buy new ones and toss these in the trash.
  11. #9
    Jul 2002
    New Braunfels, TX
    10,540
    beat the **** out of the pan with a dead blow hammer
    TXFO V.2.0
  12. #10
    Oct 2000
    Troylet , NY, US
    486
    Quote Originally Posted by TXFO
    exactly.. I had a similar problem with mine.. I used a rubber mallet to the sucker.. It dislodged it enough to peel it away from the skirt.
  13. #11
    [FJ] Addict
    Apr 2002
    19,264
    I figured that might be the answer.... I read on one "service" site that recommended banging the hell outta it on the drain bolt.
  14. #12
    Senior TEAM Member polarisman14's Avatar
    Aug 2006
    Gilmanton, NH
    4,102
    I used copper rtv on my oil pan last time and to get it out I had to get a series of small screwdrivers and get them through and push down on all of them at the same time, that way you're putting relatively even pressure on the pan instead of denting the flanged mounting points.
    --UnFocused1-- AKA >>Matt<<
    --89 Starion SHP, MPI Swap, 400hp+ or bust!--
    <03 Ranger 4.0L "SKIGOD" DD: CAI, custom side exhaust, audio>
    >86 Ninja 250R "GOPED" 50+mpg bullet: Slip-ons, Pod filters, Jet kit, LED signals, custom plate bracket<
  15. #13
    WARNING:color> This post may be hazardous to your health.
    Dec 2006
    2,219
    there are utility knives made super strong for cutting carpet and linolium and all kinds of things.
    I perfer one of these beasts, with a titanium blade aftermarket (heavy duty means thicker, edge looks gold)
    http://www.stanleytools.com/default....ractable+Knife
    if you dont have a stanley 10-788, you got the wrong razorknife.
    otherwise sillicone melts somewhere around 350-400 degrees.
    its got good heat resistance, but it eventually burns off well south of a basic propane torch.
    unfortunately, that means lots of fire in your oilpan.
  16. #14
    Jul 2002
    New Braunfels, TX
    10,540
    H-a-m-m-e-r
    TXFO V.2.0
  17. #15
    I Now Post Stupid **** Jibberish18's Avatar
    Apr 2003
    Chicago
    3,495
    Long flat head screw driver and a hammer?
    "If You Never Had The Bad Times, How Would You Know You Had The Good Times?" -DEATH
