Oil drain plug on a 2008 Ford Focus 4 cyl
FSWerks
Results 1 to 8 of 8
    Newbie
    May 2008
    1
    Default Oil drain plug on a 2008 Ford Focus 4 cyl
    Where is the oil drain plug on a 2008 Ford Focus? I would like to change the oil and cannot seem to find it.
  3. #2
    Inheritly Sinister
    Nov 2000
    Tappahannock, VA
    12,926
    Default Re: Oil drain plug on a 2008 Ford Focus 4 cyl
    (assuming they didn't change anything; I doubt they did) It is on the back of the oilpan. If you get underneath your car, you'll see the oil filter in the front, and on the opposite side of the oil pan will be the drain plug.
  4. #3
    That one was just me not paying attention....and sucking j20000's Avatar
    Mar 2005
    Pittsburgh, PA (But, San Diego at heart)
    7,509
    Quote Originally Posted by starhubs
    You didn't get any free maintenance with your car? I did.
    NEW: 2009 Ford Fusion SE - Blue Suede Package, 18" painted aluminium wheels, sport tuned suspension. GONE: -2003 SuperBlack 350z with a bunch of cool stuff
    Quote Originally Posted by LuvmyFoci
    I could handle 4-8 inches... 2 feet might be a bit much for me.
  5. Remove Advertisements
  6. #4
    TEAM Member Cedilla's Avatar
    Feb 2008
    Huntsville, AL
    656
    does the 08 have the same motor as the 05-07?
    Chris
  7. #5
    Mar 2005
    7,509
    yup.
  8. #6
    Newbie
    May 2010
    1
    The Ford Focus, the 2.0 L engine at least, as I was told by a mechanic at a Ford Dealership... is not entirely the same from 2008 on. I was told that they changed the from a belt drive OHC to a chain driven system.
  9. #7
    Nov 2004
    19,113
    Quote Originally Posted by liptoss View Post
    All North American Duratecs use a timing chain and they always have.
    The Zetec uses a timing belt but they stopped putting that engine in the Focus in 2004.
    Now accepting online orders here http://parts.autonationfordwhitebearlake.com/
  10. #8
    Dec 2009
    philly
    27
    they all use a 13mm drain plug
    01 zx3- AEM intake, B&M short throw, focus central UD pullies, focus central TB, borla catback, fidanza aluminum flywheel, vf engineering rear mount, s2 wing, eibach sportlines, 5% tint all around
