How To: Camber Bolts
Rock Auto
Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    Nov 2005
    Long Island, NY
    927
    Default Camber Bolt Question
    I spent an hour researching these little things. I received them in the mail today and I was going to install but where does the little lump on the bolt need to be placed to reduce negative camber? I am getting an alignment tomorrow but for now I want to ensure the bolt is sitting right so I dont add more camber then I already have
    ~*~*~ Built 2 Envy ~*~*~
  3. #2
    Feb 2005
    San Antonio
    361
    Default Re: Camber Bolt Question
    the lump needs to be on the inside....facing the vehicle...im sure the alignment shop will move it according though.....just let them know you have a bolt to adjust the rear camber...or they will assume you have none and just adjust the toe and not touch the camber...
    00 Pitch Black ZX3 : i hate my car...but she love me
  4. #3
    Nov 2005
    Long Island, NY
    927
    One more question, tried looking again breifly but the large tabs face the wheels correct when correcting negative camber? I saw it early but dont recall what it said
  5. Remove Advertisements
  6. #4
    Nov 2005
    Long Island, NY
    927
    Nevermind found it! I took pictures through out my whole install and I am going to create a how to for this as many people as I was going through the search feature had the same questions I had and pictures would definetely be helpful.
  7. #5
    Nov 2005
    Long Island, NY
    927
    Default How To: Camber Bolts
    I know there is a few walkthroughs on this and some people may think this is straight forward but to be honest I had to do quite a bit of research since I was going to attempt this myself. The instructions are somewhat unclear and nowone really had good quality pictures of how the bolts are installed, more importantly after shots of the bolts in place. I saw a few people requesting pics of the same thing I was after so I decided when I installed mine I would snap some pics and make a breif walkthrough.
    First of all this is the reason I had ordered the bolts.
    Step 1: Jack the car up and secure on jackstands. Some use the pinch weld as a jacking point, I used the spring cup on the lower control arm and put 2 jackstands on the rear subframe. After the car is in the air you will want to remove the rear wheels. Be sure to chock your front wheels!
    Step 2: Find the bolt that need to be replaced with the new camber bolt. You will notice the nut is tack welded. This needs to be cut to remove the nut. I used a dremel with a heavy duty cut off wheel to remove the bolt, along with a flat head and a hammer to try to pry it off.
    Note: You may want to but the jack under the lower control arm to hold it in place, I noticed it made it a bit easier to remove the bolt when the arm was raised a bit.
    ^^^Close up of the tack weld^^^
    ^^^ The Remains^^^
    Step 3: Now that the stock bolt is removed you need to grind the area where the weld was smooth so the new bolt and washers can sit flush
    Step 4: Now it is time to insert the new bolt. The first picture is how everything will be installed, a layout that many were looking for a picture of, myself included. When you install the bolt be sure to put the nut on the same side it was on from the factory. Not sure if this is crucial, but I figured since the factory did it this way, there might be a reason When putting this bolt in you need to know what you are looking to do. If you are looking to eliminate negative camber, as I was, you will want the two angled tabs facing the center of the car, and the little arrow on the bolt head facing the center as well. This will add positive camber to your set up. If you are looking to add negative camber, just spin everything around so it is facing away from the vehicle.
    Note: I was trying to get rid of negative camber so if you are trying to add camber you need to do it differently then pictured!
    Step 6: Be sure the bolt is fully torqued and dont forget to go over the lug nuts once the car is on the ground and after 50 miles as well! Dont want your pretty wheels falling off!
    Here is the finished result, a straight non cambered wheel that will save you money on tires! Paired with a good toe setting in the front will really make you a happy focus owner. I think my rear may have a bit of positive camber, which will be checked out tomorrow and I will update this!!!
  8. #6
    No Cause For Alarm MichaelXi's Avatar
    Sep 2001
    Venus Via Knoxville, TN
    17,312
    Default Re: How To: Camber Bolts
    Your first pic tells me you had a problem with Toe.... Not Camber.
  9. #7
    [FJ] Addict brads03zx3's Avatar
    Sep 2004
    Traffic
    11,368
    Pretty good writeup. I would recommend removing the bolt BEFORE grinding off the nut. Oh, and go get yourself an alignment
    Mountain Tested----'03 zetec
    ZX3 vs MNTN - 15-2 & ZX3 vs TRACK - 23/1 JCM Racing #88
    Vacuum Vulture Racing - We Make You Less Powerless
    Quote Originally Posted by norcalfocus01 View Post
    ...too short to be a dick.
  10. #8
    Nov 2005
    Long Island, NY
    927
    Actually i did remove the bolt before the nut lol. Thanks for all the help guys I really appreciate it! The rear toe was set to 0 so I figured teh camber was just offnow
  11. #9
    Aug 2006
    Connecticut
    1,088
    Looks good - nice pics.
    02 sedan se (aka The SC'd se)
    Focussport/VF vortech intercooled currently @ 201 whp & 186 wtq on 93 octane
    Hey -- we don't know nothing about kids. So if you need something... Find it yourself. Or better yet, learn to do without.
  12. #10
    Sep 2001
    17,312
    Quote Originally Posted by 2002red
    I should have Thanked you for the pics earlier too.
    Thanks for the useful thread.
  13. #11
    Nov 2005
    Long Island, NY
    927
    No problem guys! Least now the community has some good reference pictures for this install!
  14. #12
    Mar 2002
    Manassas Park, VA
    1,832
    My tire looked like yours but shredded :-( Had to get a Camber kit for the front right
    IF YOU AIN'T BOUT IT, DON'T SHOUT IT!
    02 SVT JRSC New numbers 246hp 190tq WMI SOLD :-(, 2006 SRT8 Jeep Loaded Vortech SC, 2010 C63 AMG
    www.acuzio.com
  15. #13
    Apr 2007
    Fort Wayne, IN
    2,548
    rocking the drums, nice me too LOL
    '02 Liquid Gray ZX3 - Built NA, head, cams, tune.....SOLD
    '07 Black ZX3 - Intake and exhaust on SVT suspension.
    Currently building a forged 2.5 turbo to stuff in a Focus, Ranger or fox body.
  16. #14
    Sep 2002
    Connecticut
    4,417
    Nice install but you should hit that fresh metal with a bit of self etch primer and paint to prevent premature rust!
    No one like premature ANYTHING!
    The Garage: ARIA#1211: 2002 SVTF, JASMINE#1062: 2004 SVTF Euro,
    NUGGET
    2000 Jeep Cherokee Sport 4.0, RAIN1990 Ford Escort Wagon...RIP
    "Dear Diary...Jackpot!" Giggity Giggity Goo!
  17. #15
    Apr 2004
    C-town Texas
    297
    your jackstand location scares baby jesus, and me.
    i don't mean to look up to you. your car is just so tall
    bagged wagon
