Coolant leak from thermostat housing
FSWerks
Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    Newbie
    Jul 2008
    3
    Default Coolant leak from thermostat housing
    I've read all the info I can on the thermostat housing leaking. I've come to the pretty easy conclusion that it's either the thermostat housing being cracked, or the O-Rings inside the thermostat housing being old and brittle that's causing the leak.
    Which problem is more common? Is it worth it to just buy a new housing and a box of #203 O rings and replace them both?
    Also, where did you buy your housing from? I've always used rockauto.com, and they've got it for $14 but if you recommend elsewhere, I'd appreciate the advice.
    Thanks in advance.
    Kevin
  3. #2
    [FJ] Addict GapBoyPCS's Avatar
    Oct 2001
    11,255
    Default Re: Coolant leak from thermostat housing
    A lot of people have bought the housing and parts from Premier Sponsor, Tousley Ford. You can't go wrong with 10% over cost
    Richard
    2002 ZTS | Sangria Red |
  4. #3
    Newbie
    Jul 2008
    3
    Would you recommend that I purchase the O rings and housing and just get them both over with now, or is it more than likely one or the other causing the problem?
  5. Remove Advertisements
  6. #4
    Apr 2007
    Fort Wayne, IN
    2,548
    The housing generally cracks in the portion that surrounds the O-ring. So the O-ring is no longer bound in a circle. The housing cracks before the O-ring goes bad. But put in all new when replacing , T-stat, housing, O-ring.
    '02 Liquid Gray ZX3 - Built NA, head, cams, tune.....SOLD
    '07 Black ZX3 - Intake and exhaust on SVT suspension.
    Currently building a forged 2.5 turbo to stuff in a Focus, Ranger or fox body.
  7. #5
    Newbie
    Jul 2008
    3
    What # is that O-Ring? I thought it was a #203 but now I can't find anything to back that up..
  8. #6
    Apr 2007
    Fort Wayne, IN
    2,548
    Quote Originally Posted by kcackler
    Knowing the number really means nothing, just get everything from the dealer. They will get you the right part.
  9. #7
    May 2004
    82
    what you need it the housing, a new o ring for the th thermostat andsince you will be in there might as well replace the thermostat as well that way it is done.
    that is what I did.
  10. #8
    Mar 2002
    Southeast Michigan
    485
    Typical spotty Ford quality. I love to drive my 2001 Focus ZX3 S2 and it has been troublefree so far, but with 85,000 miles on it I'm starting to get worried about stuff like this happening that shouldn't happen.
    I've had a slight valve cover leak for some time now. Didn't think much of it. Then the other day the thermostat housing started leaking. This is what my leak looks like:
    Very strange place for a leak, you're looking at the lower middle bolt. So I didn't think I'd be the only one with such a problem. Thanks for the tip about what causes the problem.
    Needless to say that when I replace the thermostat housing and O-ring I'll be replacing the valve cover gasket at the same time.....
  11. #9
    Jun 2005
    Washington, P.A. formerly Phoenix A.Z.
    760
    I just got bit w/the thermostat housing being cracked as well as the valve cover leak. I guess when it rains it pours.
    Focus Sport Short Ram Intake,Focus Sport Strut Tower Bar, Blue Laminex Headlight and Foglight kit,Fog light Hack ***JCM RACING #52***
  12. #10
    Mar 2002
    Southeast Michigan
    485
    Here's a picture of my cracked housing.
    Looks to me like it could be a manufacturing defect/poor design, wonder if there will be a recall?
  13. #11
    Apr 2008
    SLC, Utah
    58
    My housing was cracked and they just replace the whole thing at the dealership. Now there are no more ugly puddles under my car!
  14. #12
    Newbie
    May 2009
    1
    Quote Originally Posted by GTIspirit
    The photo is great. Mine has a puddle in the same spot, but it looks to be well behind the thermostat housing. Could you verify that it's the thermostat housing that's leaking? Thanks.
  15. #13
    May 2009
    Urbana, IL
    8
    yes it is the housing...but most of the time it is caused by the valve cover leaking...causing the thermostat housing to be soaked in oil causing the seal to expand and leak like a sive...I have done probably 20 of these things this past year alone...the focus' were terrible about these things
  16. #14
    Apr 2001
    Los Banos CA
    255
    mstang got it right. Working on these for all these years now this is exactly what we see. The Valve cover usually starts leaking and the oil leaks down onto the T-stat housing and it starts leaking.
    MaDawg
  17. #15
    Newbie
    Aug 2006
    Upstate NY
    2
    You can expect to replace them every few years or so. I replaced mine on my ZX5 when it dumped the entire contents of the cooling system one night at 103,000 miles or so. This is on a car with no valve cover leak.
    HTP has the only alternative I have seen, a milled aluminum thermostat housing. I have one on order from them for my SVT.
    Sona si latine loqueris
