Changing Headlight Bulb in 2006 Focus ZXW
Tire Rack
Results 1 to 6 of 6
    Newbie
    Dec 2008
    3
    Default Changing Headlight Bulb in 2006 Focus ZXW
    Hi All,
    I own a 2006 2.0 Focus ZXW SES. I have a passenger side headlight out.
    I purchased a new bulb according to the specs. It is hovering around -28 C right now so I'm trying to do this in the garage so I don't freeze. I went out today and took off the little circle plastic rubber off the back of the bulb. But now I'm at a standstill!
    What do I do now? Is there a metal pin that I have to push? I'm lost.
    Help?
    Thanks.
    Brett
    Focus owner since 2000. (I'm on my 4th now!)
  3. #2
    Feb 2001
    Westwood, MA
    52
    Default Re: Changing Headlight Bulb in 2006 Focus ZXW
    theres a procedure in the manual. i seem to recall.
    ZX3- Twilight Blue South of Boston
  4. #3
    Aug 2008
    maryland
    665
    if you see the bulb grab it and twist it out.. whats the issue?
    2002 mach edition zts blacked out tails and turn signals h.i.d headlights 8000k and magnaflow catback exhaust, orange/black,interior,chrome strut bar kicker audio flip out jensen 7in dvd/cd
    2004 expedition loaded 5.4l,1990 ranger 2.9l
  5. Remove Advertisements
  6. #4
    Newbie
    Dec 2008
    3
    I can see the back of the bulb with the wire's attached.
    I cannot seem to twist it or move it at all. That's where I'm stuck.
    Is there a locking mechanism that holds the bulb in place?
  7. #5
    Newbie
    Dec 2008
    3
    I checked the manual.
    The instructions I have are:
    Remove the Rubber casing off the back
    Twist bulb counterclockwise
    pull backwards.
    When I try twisting counterclockwise it doesn't move.
    I can "strong arm" it straight back out but that pulls off the wire housing. There is a clip on the top also.
    Starting to get stumped here.
    Thank you for all your help in advance.
    Brett
  8. #6
    Aug 2008
    maryland
    665
    must just be jammed. just twust it but dont do it hard enough til it breaks. try both ways. they arent h.i.d's right?
