How to fix p0135 engine code
Tire Rack Winter 2015
Results 1 to 12 of 12
    Apr 2005
    San Jose, CA
    1,666
    Post How to fix p0135 engine code
    Many people tend to get this P0135 Code.
    What does that mean?
    This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135.
    Page copy protected against web site content infringement by Copyscape
    Symptoms
    You will likely notice poor fuel economy the illumination of the MIL.
    Causes
    A code P0135 may mean that one or more of the following has happened:
    * O2 Heater element resistance is high
    * Internal short or open in the heater element
    * O2 heater circuit wiring high resistance
    * open or short to ground in the wiring harness
    Possible Solutions
    * Repair short or open or high resistance in wiring harness or harness connectors
    * Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
    http://www.obd-codes.com/p0135
    I wanted to start a thread with possible fixes and things to check if you encounter this problem. Some people have actually had problems with the wires rubbing, so please post pictures of that if anyone here has a picture of it.
    Here is a believe to why my p0135 keeps coming on and off. I've ordered a new o2 anyways.
    So anyways, my p0135 would come on from time to time and run really crappy. So i pulled my o2 out and sprayed it with some electrical cleaner, then I checked my #18 fuse and it was still good. But i noticed some corrision forming on the contacts.
    -So I used a really small screw driver to push the connectors closer together and sprayed some electrical cleaner on the contacts, then i took the small screw driver and rubbed the contacts.
    -After that i took the fuse and pliers then pulled the fuse in a out of the slot a few times to clean it thoroughly.
    The CEL is now gone!
    Garage as of 5/19/14
    2003 Focus ZX3 Turbo 2.3L
    2003 Focus ZTW
    2003 Honda Civic Hybrid
  3. #2
    Aug 2000
    24,330
    Default Re: How to fix p0135 engine code
    Nice going if it stays off.
  4. #3
    Nov 2008
    Norristown, Pa
    161
    Nice, Im going to pull mine tonight, clean it off and check the connections.. Then Ill order a new o2
    04 SVTF Daily Driver
    96 Cobra Built and Blown 536RWHP/465RWTQ
  5. Remove Advertisements
  6. #4
    Apr 2005
    San Jose, CA
    1,666
    My p0135 CEL hasn't come back yet, But I installed a new o2 sensor about a week ago anyways. I'm at 45k miles
    2003 Focus ZTW
  7. #5
    Jul 2009
    45
    my fuse also keeps blowing could the back o2 sensor blow the fuse I had the same code just placed mine yesterday and still blows
  8. #6
    Mar 2006
    OKC, OK
    8
    I'm getting this code. Checked my fuse and it was blown. Replaced it and cleared my CELs. Drove it around a bit. Stopped and turned it off and back on a couple times too. No CEL as of yet.
    I'll keep an eye on it and update later.
    14.9 @ 94.07 (2.228 60ft.) No, I'm not stock.[thumb]
    "I feel lethal."
  9. #7
    Mar 2006
    OKC, OK
    8
    p0135 code is still gone but I did get the p0133 again. I had it before though. That'll
    be my next project.
    "I feel lethal."
  10. #8
    Apr 2005
    San Jose, CA
    1,666
    Glad to hear it helped someone!
    2003 Focus ZTW
  11. #9
    Oct 2009
    516
    having the same problem right now...
    Can you help?
    http://forums.focaljet.com/team-tech...lp-please.html
    WTB 67mm SVT TB
    Please PM me..
  12. #10
    Mar 2011
    27
    I'm having a problem with this too I hijacked someone else's thread with some suggestions but I have yet to solve the issue.
    I replaced the o2 sensor, cleared the code, put in a new fuse and it just blows the fuse every time.
    I put in a new fuse and instantly when i turn the key the fuse blows.
    I have checked wiring (nothing obvious)
    I have tried unplugging the sensor clearing the code replacing the fuse, when I turn the key the fuse instantly blows. I'm pretty sure its a wiring issue.
    Is there a common spot for wires to be worn at?
    I thought about adding Dielectric grease but thought that would worsen the shorts
    I also got tired of dropping my cat to change the o2 so I had it relocated to the side but this I dont think this has anything to do with an electrical short
  13. #11
    Dec 2001
    SE Michigan
    844
    With the fuse blowing immediately (as opposed to intermittently) it actually makes locating the probable wire short much easier.
    1) Disconnect the HEGO sensor.
    2) Remove the fuse that is blowing and place a 12V test lamp (or a buzzer if you have one) across the terminals in its place
    3) Turn the key on
    If the circuit is shorted to ground, the test lamp will now be lit, and it will also protect the wiring from damage. You can now wiggle test the harness (just a small section at a time is recommnded) until the test lamp goes out. As soon as the lamp goes out you've found the area of the short.
  14. #12
    Mar 2011
    27
    thanks man. I'm assuming the HEGO is the front o2 sensor.
