help: steering wheel lock?
FSWerks
Results 1 to 7 of 7
    Feb 2004
    KCK
    1,683
    Default help: steering wheel lock?
    mod delete please
  3. #2
    TEAM Member dhardison's Avatar
    Oct 2007
    Delaware, OH
    954
    Default Re: help: steering wheel lock?
    Remove the lower plastic steering column cover. Right below the ignition lock you'll see a round disc about the size of a quarter. Take a small screwdriver and pry that disc out (don't worry about damaging it, as it will not go back). When that disc is removed the ignition locking pin will fall right out. Wa-La no more lock.
    I had to disable the ignition lock per the SCCA rules and this worked great for me.
  4. #3
    Feb 2004
    KCK
    1,683
    sweet, hopefully the 09 is setup the same way
  5. Remove Advertisements
  6. #4
    Feb 2004
    KCK
    1,683
    well no go that way. guess they set the new ones up different. I tried calling ford and they don't know so i'll try focussport and see if they have anything.
  7. #5
    Feb 2004
    KCK
    1,683
    success! well after a couple hours ofclose examination and carefully testing I got it done. the entire ignition setup had to be removed and partially disassembled and then removed the return spring under the pin and then secrued it down. def not for the faint of heart. Once I get the Start button in I want and get it redone the way I want it I'll post a write up on it.
  8. #6
    Oct 2007
    Delaware, OH
    954
    Good job!
  9. #7
    Newbie
    Feb 2015
    1
    hi guys, i know this was a long time ago but does this work on an 03 focus? somehow while replacing my worn out ignition barrel the steering lock has activated and I cant figure out how to release it.
    there is a metal plate under the assembly. if i remove it will the steering lock parts fall out and permanently disable it?
    cheers
