Rear End swaying/sliding back and forth on wet roads
Rock Auto
Results 1 to 8 of 8
    Newbie
    Dec 2009
    4
    Default Rear End swaying/sliding back and forth on wet roads
    i have a 2001 ford focus . for the past year i have been dealing with a swaying/sliding motion in the rear end of my car on wet roads, even worse on snowy roads. i tell people it "dances" down the road. it doesnt do it on dry roads, well other than when i hit a bump on dry roads the whole rear jumps from on side to the other i guess depending on what tire hit the bump. whatever is causing that i think is tied in with the swaying problem on wet roads. this car is very scary to drive when its wet out. i have looked under it to see if anything is visually wrong, and dont see anything. i dont really want to pay a garage 500 bucks to diagnose it. someone please help me, hopefull someone that had the same problem!
  3. #2
    [FJ] Addict GapBoyPCS's Avatar
    Oct 2001
    11,255
    Default Re: Rear End swaying/sliding back and forth on wet roads
    Welcome to FocalJet.
    This post may give you some insight. It may well be that you have some worn suspension components, and/or your alignment is at the incorrect setting. Tires may also play a part in it.
    What is your car's mileage? Have you done any modifications to your vehicle?
    A garage shouldn't be $500. At most, you have to pay $150 or what's usually called a Diagnostic Fee before you grant your permission to do the work.
    Richard
    2002 ZTS | Sangria Red |
  4. #3
    Newbie
    Dec 2009
    4
    the car has 129,000 miles. someone else told me maybe the alignment is out of wack, the suspension components seem tight. the tires need replaced, which i plan on doing at the end of december, and get an alignment at the same time.
  5. Remove Advertisements
  6. #4
    Newbie
    Dec 2009
    4
    Oh, and no i have done no modifications to it.
  7. #5
    Mar 2008
    Farmington Hills, MI
    1,911
    In my case it was toe issues from having my car lowered a significant amount. Even thought you don't have any suspension mods it's probably in need of an alignment. Gapboy summed it up pretty good. New tires and alignment will probably set you straight (no pun intended!)
  8. #6
    Nov 2007
    San Carlos, CA
    97
    shocks are probably bad. That is what keeps your wheels on the ground. From the sounds of it your tires have trouble staying connected to the road. On the dry surface they still have some grip, but on wet they just aren't in contact with the ground enough.
    So when your wheel hits a bump, shocks suppose to absorb it and not let your springs take over and bounce your wheel back. Since your shocks probably are no good now, your tires bounce too much, thus no traction
  9. #7
    Newbie
    Dec 2009
    4
    if my shocks were bad the car would be bouncy when i hit bumps, but it actually feels real stiff, when u hit a bump u feel it in this car. ive been behind cars with blown out shocks, the hit a bump and it just keep bouncin
  10. #8
    Junior Member 01slo-cus's Avatar
    Sep 2009
    57
    Bad tires and alignment out of whack will cause exactly the problem you describe. Get some decent rubber under there and take it to a shop that does 4 wheel alignments. There are some shops that only do a "toe and go" on the front. Make sure you take it somewhere that'll align all 4.
    2001 ZX3 CAI, ported TB, SVT header, UDP, 2.5" exhaust and still barely gets out of it's own way!
