Engine Seize
FJ Gear Store
Results 1 to 14 of 14
Thread: Engine Seize
    May 2007
    Honolulu
    97
    Default Engine Seize
    Hello all, been a real long time since I've visited the site...
    Something horrible has happen to me recently and thought I would share my anguish with the jet.
    Long story short, driving to work yesterday, I loose oil pressure and oil light comes on.. On freeway at this time, pull car to the side, turn car off and pop hood...
    Inspection reveals oil cooler hose popped off...
    Call tow truck, have them tow it to my house, fix hose, replace oil..
    Car turns over and immediately dies... Oh know I'm thinking!!!
    Turns out after trouble shooting, engine is seized..
    Culpret= failed hose clamp and poor reaction time..
    2002 InfraRed SVT: XIOS Turbo@9psi-Tuned by FocusSport, Torsen LSD, Competition Stage III Clutch, Spec Aluminum Flywheel, Steeda STS, FC Pulleys, CFM HiFlow Cat, Trubendz Borla 2.5, Koni Adjustables, Progress Rear Sway and Springs, FS strut brace, VF Rear mount, OZ Chrono Evos, ST170 headlights w/ euro grill
  3. #2
    Senior TEAM Member COSVT03's Avatar
    Oct 2004
    Minneapolis, MN
    4,662
    Default Re: Engine Seize
    That is a bummer my friend! I feel your pain!
    Have you ever doubled up hose clamps on critical engine lines such as tranny cooler lines?
    I'm happy to say, the tranny going into my truck will be beefed up and ready to haul, and be running cooler!
    #3052 of 3985
    Full N/A SVT Build
  4. #3
    May 2007
    Honolulu
    97
    Never really thought I would need to do that... But makes since considering.
    I should have used different clamps from the beginning... The clamps supplied with fs oil cooler kit are the crimp style, so if anybody gets this kit, please use different clamps...
    Expensive lesson learned!
  5. Remove Advertisements
  6. #4
    Copying CaysE's mods even before CaysE does them! WRCwannabe's Avatar
    Feb 2009
    DFW TX
    2,265
    sell me your turbo kit
    Wings & Teeth™
    "Dont hate the 4x108"
  7. #5
    May 2007
    Honolulu
    97
    Not ready to put the focus to rest just yet...
    Another engine on order.
  8. #6
    Go ahead - ask me how Chalz' huge, bulging, fearless testicles taste DigitalGT's Avatar
    Nov 2004
    Jax, FL, USA, Earth, Sol, Local Cluster
    3,240
    Dude that really sucks. I'm sorry it happened to ya. Is the engine really seized though? Like put a breaker bar on the crank and it won't budge, seized? If you're lucky you might find that it will only take a little machine work and a few new components to get it running again. It would suck to replace the engine out right only to find the fix was a line bore and a set of bearings. I hope it works out for ya.
    If you own a ZETEC Focus, your alternator is either broken or about to be.
  9. #7
    Senior TEAM Member blackbird's Avatar
    Nov 2002
    Temecula, CA
    1,867
    Sorry to hear your troubles. Looking at the modifications listed in your signature it looks like it was a fun car and hopefully you can get it back on the road soon. If you get a new engine also make sure to really flush and clean (or replace) the turbo oil feed and drain lines and flush the center section of the turbo with clean oil in case some debris made it to them when the bearings started getting chewed up in the engine.
    Eric H.
    '13 ST (Tux Black) - '04 SVTF (Screaming Yellow/EAP ZX3) - '02 SVTF (CD Silver - Vortech)
    '92 Dodge Daytona IROC R/T - '81 & '85 Chevy Citation X-11 - '93 Olds Achieva SCX W41 (x2)
    plus a Cobalt, a Neon, and a bunch of other stuff...
  10. #8
    Oct 2004
    Minneapolis, MN
    4,662
    The crimp style you need a special tool for? Those are way better than what I am talking about. But it still doesn't hurt to double up on those either.
    #3052 of 3985
    Full N/A SVT Build
  11. #9
    May 2007
    Honolulu
    97
    Well, seems my mechanic is having a hard time finding a replacement engine for me, so guess I'll have to do some searching my self. I wish I could tackle this job my self, but live in a apartment...
  12. #10
    May 2007
    Honolulu
    97
    Unhappy Re: Engine Seize
    Quote Originally Posted by DigitalGT View Post
    I tried to turn the crank manually, didn't budge..
    Also put it in fifth and tried pushing the car forward, and nothing...
  13. #11
    is REALLY worried about very little things... bmylez's Avatar
    Dec 2007
    San Antonio, TX
    5,145
    Sounds like it's low on blinker fluid, that's all
    Sorry to hear that man. How long did you drive it after losing oil pressure? I would think there would be a slight grace period, especially if you weren't railing on the car. John ran his car down to about 12.5psi of oil press. before getting off the road and his motor is fine. I guess you had 0, though, not 12. Did you check to see what your oil level was before filling it up?
    1992 Eagle Talon TSi AWD - broken/sold
    2002 Mustang GT - sold
    2002 SVTF - sold
    2008.5 Mazdaspeed3 GT - Cursed
    2003 350Z Track - basically stock, and it runs
  14. #12
    Camera 1, Camera 2..Camera 1, Camera 2 svtf02red's Avatar
    Jun 2003
    On a freakin' conference call - again.
    7,494
    Dude, I'm sooo sorry to hear about that. That really sucks being that you're on the islands, too. Well, nothing about living on the islands sucks, but getting a hold of not-so-common parts must be difficult.
    Not sure if you've seen this site before, but this is how I found my SVT engine:
    http://www.car-part.com/
    They may not list an actual SVT engine, but as blackbird pointed out to me - search for yards that have the Getrag 6sp in stock - there's a better chance they'll have an SVT engine. Just call the yard and make it very clear you are looking for the SVT engine with a "5" in the 8th character of the VIN. Being that shipping won't be anywhere close to reasonable, you'll want to get this right the first time. See if they can give you mileage verification, too. Good luck
    The official bearer of bad news for those with questions about their SVT woes.
    "Inside every cynical person, there is a disappointed idealist" - George Carlin
  15. #13
    May 2007
    Honolulu
    97
    Quote Originally Posted by bmylez View Post
    Honestly, I don't really know how long I lost oil pressure for before I noticed.. Plus the hose that popped was the oil return line from the oil cooler, so I imagine I probably lost alot of oil really fast..
    Luckily for me considering, I have another mode of transportation until I get this resolved..a nice torquey little Suzuki SV650. Really fun to ride, just sucks when it rains!
    Steve being the good guy that he is, has been nice enough to find some options for me.. Thanks Steve!
    I did call around locally looking for an engine, but unfortunately the SVT being as rare as it is, it is even more rare here in Hawaii.. I'll more than likely be doing this job my self since my friend volunteered his garage, so I'm just praying I get a good engine when I do, so I don't have to tear it back out again.. That would really suck!
  16. #14
    May 2007
    Honolulu
    97
    Quote Originally Posted by svtf02red View Post
    They have a couple listed on the site you gave, sent some emails... Thanks a lot!
