Bypassing the fuel rail pressure sensor
FSWerks
Results 1 to 8 of 8
    Senior TEAM Member QJKXBM's Avatar
    Feb 2008
    Scottsdale, AZ
    1,515
    Question Bypassing the fuel rail pressure sensor
    I've been having an annoying problem with the fuel pressure sensor that is mounted to the fuel rail on my Duratec. It seems as though they are designed to read vacuum, and use the vacuum signal to provide the required fuel pressure to the rail, but since my car is boosting 18psi now, it tends to throw engine codes when I stomp on it (likely because the ECU thinks its reading some impossible pressure and therefore broken).
    Is there a way to bypass this sensor or delete it altogether? How would the fuel system need to be designed in order to do this? I was told to get a new sensor, and that some sensors are more forgiving than others, but this sensor is brand new and it's throwing codes when i boost hard, so I'm reluctant to purchase a new sensor hoping the issue will cure itself..
    Power: electric supercharger, tornado intake, cherry bomb muffler, platinum cross fire plugs (more to come)
  3. #2
    Premier Sponsor FSWerksTECH's Avatar
    Feb 2005
    2,491
    Default Re: Bypassing the fuel rail pressure sensor
    You may have a fuel pump thats starting to go bad or just not keeping up anymore. You should do a 3rd gear WOT datalog and send it in to Randy for him to analyze.
    2004 Golf R32 Turbo -- (375fwhp @12psi) My daily driver
    2004 Golf R32 -- (231fwhp) Race car/street car (AWD Kicks Butt)
    1993 Corrado VR6 Race Car -- Sitting for the past 8 years
  4. #3
    I AM THE MOFREAKINGMAN!
    Apr 2006
    Westchester, CA
    6,762
    yeah do a data log and make sure your fuel pump is square, but most likely its the same issue i deal with, it throws the code P0191, which is excesive fuel pressure in the fuel rail, i just always think to myself, im boosting 20psi, no duh theirs excessive fuel pressure
  5. Remove Advertisements
  6. #4
    Feb 2008
    Scottsdale, AZ
    1,515
    yah, clint I was hoping you'd chime in. I remember Randy telling me you had dealt with the same issue. I'm getting the same code, P0191
    I imagine the fuel pump is ok since Randy didn't mention the datalogs looking odd after I brought the car back in the second time for a retune. I remember the code coming up right away. But I'll do a datalog anyway just to make sure. No sense in risking it i guess.
    Thanks Vik and Clint
  7. #5
    Apr 2007
    Fort Wayne, IN
    2,548
    I'll sell you a return style fuel rail, and just get rid of that FRP sensor all together. That won't help the CEL but would be a way better setup for a boosted car.
    '02 Liquid Gray ZX3 - Built NA, head, cams, tune.....SOLD
    '07 Black ZX3 - Intake and exhaust on SVT suspension.
    Currently building a forged 2.5 turbo to stuff in a Focus, Ranger or fox body.
  8. #6
    Senior TEAM Member Ja-Red's Avatar
    Jul 2008
    2,600
    Quote Originally Posted by Liquid_02_ZX3 View Post
    As far as I know you must have the fuel pressure sensor with a returnless fuel system. If you go to a return style you can delete it, I did. and I'm running great.
    Gone but not forgotten 2003 ZX3 zetec GT3582R 561whp 434wtq @ 25psi
    Best et 11.40 Best 1/4 mile mph 132 on 93 octane
    My Thread
    New whip, 2005 liquid grey ST 148k and counting
  9. #7
    Feb 2008
    Scottsdale, AZ
    1,515
    yah, that's what I would like to do actually. can you PM me with the details of it?
    Jared, what is all involved with setting up a return-style?
  10. #8
    Stolle's Avatar
    Aug 2006
    Whereever its Miller Time! AKA: WI
    4,926
    a pump. a new feed line. use the stock feed as the return. a FPR. random fittings and line.
    bryan at top speed has a shopping list jared sent me that i told bryan to put together. but thats for a zetec but i cant imagine the duratec taking much different then a duratec rail modded to be return style.
    2001 Infra-Red ZX3. R.I.P. Old Engine (613whp/505ftlbs@35psi) New One Being Built
    2002 CD Silver SVT. Street Car. Mostly Stock. 1 of 513 made.
    Ambition is priceless It's something that's in your veins And I put that on my name.
